Operating A Water Source Unit With No Water?
Old 12-24-2008, 10:41 PM   #1
3lbfinishhammer's Avatar
Trade: general
I am a framing carpenter who knows a little about some things and less about everything else. I am working on my own house and I am in the process of installing an open loop water source unit (McQuay Enfinity 4 ton unit) and I was wondering if it can be operated make heat before the water piping is in place? I understand that it wouldn't be as efficient as it would with the proper water flow, but will it work and could it possibly cause any damage? This would only be a temporary thing until such time the pipes can be trenched in. Thanks in advance
3lbfinishhammer is offline
Old 12-25-2008, 04:58 AM   #2
snapperhead's Avatar
Trade: commercial hvac repair and installations
Re: Operating A Water Source Unit With No Water?
with it in the heating mode(inside coil is hot) the water side needs a load because of it being the cooling side now.with no water running thru the condenser the unit will trip on low pressure(if it has one) or you crack the condenser piping in that "that CAN looking thing,or race track piping setup" within the unit.for temporary heating hook up a water hose to the condenser.......IN>>>>>>>>>> and a hose to OUT>>>>>>>>>to drain it.you don't need to completly open the water to it,just enough to get the LIQUID LINE warm with the unit in the heating mode.the LL is the thinnest copper one that runs from the condenser to the evaporator coil.if you can mix hot/cold off a faucet that would be better.then you can get the water to about 75F-80F going into the condenser....that thing will bang the heat with that water entering the condenser at that temp
snapperhead is offline
Old 12-25-2008, 07:51 PM   #3
palacegeo's Avatar
Trade: Geothermal Systems
It will not operate (for longer than two minutes ) with out water.
Dewayne Dean
www.palacegeothermal.com
We heat and cool with dirt.
Why settle for 90% when you can have 400%
palacegeo is offline
Old 12-26-2008, 08:19 AM   #4
Trade: general
Ok, thanks guys...I wasnt sure if it would work like that or not. So thats why I wanted to ask someone who would know before I go and do something stupid.
I like the idea of using a water hose to at least get it up and running. Thanks guys.
water water everywhere genecarp General Discussion 7 09-07-2008 08:54 PM
Tapping into Galvanized Water Main mtbmac Landscaping 2 09-06-2008 05:44 PM
odd Goodman package unit problem airwick HVAC 3 07-17-2008 11:36 PM
Hot Water Heater Propane or Electric? robertc65 Plumbing 11 02-19-2008 12:15 AM
#&*@! Water Hammer! Mike Finley Plumbing 19 02-22-2007 11:47 PM
