Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 10-18-2005, 07:00 AM   #1
Remodeler
Trade: Remodel
oil tank location question
Hallo -
can anyone enlighten me on the NFPA code. Specifically I need to know how close I can locate an above ground oil storage tank to the burner and electrical panel. I know the NEC code about clearances to the front of panel but I don't know anything about left or right to it.
This is your standard oil tank in a single family dwelling. The local oil company doesn't want to place the tank where I had specified it. No they don't want to move it citing some code requirement. I suspect they just don't want to go to the extra labor.
Thanks ...
Vermonster is offline   Reply With Quote
Old 10-18-2005, 11:13 PM   #2
tin man 318
Trade: Hvac
Send a message via AIM to Casey's HVAC Send a message via Yahoo to Casey's HVAC
did the say what code it was that says they cant move drum, i know that code in front of ele. box is 15" onside from center and 3 foot to the front , thats mich code
Honey, I'm going to work. I'll be home when ever i get home . :Thumbs: Bj's heating is the **** :Thumbs:
Casey's HVAC is offline   Reply With Quote
Old 10-19-2005, 06:59 AM   #3
Remodeler
Trade: Remodel
Thanks ... yes. That's the only code I am aware of that aplies to the panel (NEC).
But what about the NFPA 30 and proximity to the burner? Anything there?
Thanks again
Old 10-19-2005, 08:14 AM   #4
Trade: plumbing and heating
Around here the local fire department inspects all oil installations. The oil outlet of the tank has to be min. 5' from the burner. So in tight spots we just spin the tank around. As far as the electrical panel nothing can be within 3' up,down,diagnal or sideways.
plumguy is offline   Reply With Quote
Question about bidding vinyl wallcovering kanadaeh Painting & Finish Work 9 02-19-2009 05:29 PM
Propane tank relocation... ruskent HVAC 4 03-19-2007 12:05 AM
Oil Tank KGB HVAC 1 03-18-2007 07:54 PM
