Oil Furnance Stack
The stack on my parents furnace is cracking where it meets the chimney. Please forgive me if I am wrong on terms. They have had 2 seperate contractors out over the past 3 years or so and the last one bragged about how he knows how to do this right and it will never fail, yet it has been less than a year and the sealant is cracking. What is the correct way of fixing this?
Trade: H.v.a.c.
Re: Oil Furnance Stack
Why not run new piping inside of the chimney? re-pipe the whole thing. I suspect the flue/chimney may be oversized, and the cracking is due to condensation.
not to correct a fella with terms, but, I think one spells nows with a K...
#3 | |
Re: Oil Furnance StackQuote:
I am not sure why not. I am not a HVAC guy, but will look into it. |
The cement should have been refractory cement. The stack you are referrring to is a connector going into a thimble. If you have changed your furnance to a higher efficency from what you once had more condensation can be present and erode the clay liner. If there is a clean out open it up, if there is clay debris from the flue you will need a new liner insert.
Trade: chimney inspector, consultant, and contractor
You need a Level II inspection and a listed chimney liner.
Hearthman
Keep the fire in the fireplace! Certified Fireplace Inspector & Master Hearth Professional UL Standards Technical Panel 103 BoD HPBA & International Assn. Fireplace and Chimney Inspectors |
| why would a plumbing stack 'break' | 72chevy4x4 | Plumbing | 4 | 12-22-2008 06:48 PM |
| High Stack Temp Woes | RopeaGoat | HVAC | 5 | 03-01-2008 09:43 AM |
| Can I install a A coil in a down flow furnance | bubba99 | HVAC | 2 | 06-03-2007 04:11 PM |
| Distance to stack | rusty_5620 | Plumbing | 2 | 02-22-2007 12:14 AM |
| 2 blinks on goodman furnance? | Herman | HVAC | 2 | 04-09-2006 11:16 PM |
