Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-14-2009, 12:23 PM   #1
Trade: Plubing/Heating Installations
Question Oil burner problem
Hello,
After cleaning 8 yr old Burnam boiler with Becket AFG burner, flue etc and changing filter, screen and correct nozzle things seemed fine two weeks ago. Now about 50% of time after around 14 seconds or so it sounds like a studdering one to three times but burner keeps going and completes cycle each time. What direction should I be looking at?
bobm202 is offline   Reply With Quote
Old 01-14-2009, 05:30 PM   #2
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Could be: cold oil, if single pipe system, try bleeding well, for squats change the nozzle again.I have had nozzles be bad from git go
skymaster is offline   Reply With Quote
Old 01-21-2009, 10:48 PM   #3
Trade: HVAC
Have you considered a Tigerloop? Sounds like air from here.
Willis15 is offline   Reply With Quote
Old 01-22-2009, 03:11 PM   #4
Two pipe system here. I was thinking to look up chimney with mirror to make sure no nests but i might just try to change the nozzle.
Old 01-22-2009, 03:14 PM   #5
Two pipe system here and it ran 8 yrs without this problem so I think it might be something Else.
7000w generator problem ZV 5.4L Tools & Equipment 2 12-29-2008 08:16 PM
Stain not dark enough problem Jerdog44 Painting & Finish Work 5 12-24-2008 05:31 PM
Bosch 12 dual mitre saw, transport lock wont hold? commen problem? woodworkbykirk Tools & Equipment 10 10-28-2008 08:18 PM
eifs problem Dorin Morgos Masonry 24 10-05-2008 03:10 PM
Concrete stain problem Forry Concrete & Paving 6 09-02-2008 08:10 PM
