Trade: building wooden portable buildings
No Filter
What are all the bad things that can happen if a filter is not used in a central air system? I'm having this problem at my rent house. Thanks.
Trade: General Contracting / Handyman
Re: No Filter
You plug the evaporator with dirt thats a no no. Causes your systems efficiency to drop a lot, also your unit will constantly trip. Shortening your systems life span.
solar guy
Trade: solar contracting
Re: No Filter
First you will get dirt on the evaporator coil and efficiency will drop
Then the coils will freeze up blocking all airflow and the unit runs continuously but no cooling. worst case scenario is liquid refrigerant gets back to the compressor and freezes and snaps a reed valve = new compressor |
Re: No Filter
Thanks for your prompt answer, I had told renters that I would clean filter but she said they would do it, should have checked sooner. Anyway now the framework for filter is missing, may have to fabricate one. I was afraid of your answer, I knew that dirt would collect on A-coil and make system work harder but didn't know about reed valve.
What is the best way to clean A coil? Last edited by barnbuilder1; 05-22-2009 at 06:35 PM. Reason: ask question |
Trade: remodeling and restorations
Re: No Filter
I don't think you want dust bunnies caked on the motor that runs your blower, or caked on the printed circuit board (furnace control board).
It's bad to run with a plugged filter and it's bad to run with no filter. |
| Filter Room | Shoreline58 | Plumbing Picture Post | 1 | 12-20-2008 10:40 PM |
| Filter box on top of coil | flashheatingand | HVAC | 10 | 11-11-2008 06:46 PM |
| Water filter How Much? | Mellison | Plumbing | 4 | 09-13-2008 03:26 PM |
| Filter to instant hot water dispenser | novicepro | Plumbing | 15 | 08-20-2008 12:35 AM |
| Softner or new filter ssytem | skidmark845 | Plumbing | 1 | 07-11-2006 12:59 PM |
