I owned a Craftsman home from 1922 and had the same problem. Right or wrong here's what I did. Insulated duct up through old chimney, no longer in use, with a booster wired in to furnace in basement. This fed two 12x16 rooms through the north wall. For a return I used two 3" PVC pipes cut into approx. 24" pieces and spliced together in side of chimney one by one, twice, for two 3" returns. Both returns I then ran under floor to bathroom on the south, and opened the floor. Used OEM gravity cover from house. Another heat duct and plumbing for bathroom came up from a pocket door cavity below also. Like I said, right or wrong, but it worked well.
