New Venting Through A Chimney.
Old 08-07-2009, 04:43 PM   #1
flashheatingand's Avatar
Trade: H.v.a.c.
The current venting setup on this job is one common vent for an 80% furnace and water heater through a chimney.
I am considering pulling out the existing vent, and running a 4"b-vent for the w/h and the pvc vent for a new furnace. has anyone done this? If so, what are some things that I might want to be aware of?
flashheatingand is offline
Old 08-07-2009, 06:51 PM   #2
gene2's Avatar
Trade: HVAC
Re: New Venting Through A Chimney.
If you are doing a 90% + furnace, I see no problems, done this many times. Just seal the masonry chimney up top to stop draft & rain. Sometimes I leave it open for combustion air though if a one pipe furnace. We usually do two pipe though, but the water heater needs air many times.
gene2 is offline
Old 08-08-2009, 03:57 PM   #3
Trade: H.v.a.c.
Thanks Gene, I was concerned about the spacing between the pvc vent and the B-vent. I don't think the heat from the b-vent would "melt" the pvc, but was curious if that might be an issue. I guess if there was a problem, you would have heard about it by now.
Once again, thanks for the input.
Old 09-07-2009, 02:52 PM   #4
coolmen's Avatar
Trade: hvac
all codes apply that 1" clearance from bvent to any cumbustable materials
coolmen is offline
Clearance problem for chimney GregWCIL Masonry 3 07-07-2009 10:54 PM
Suggestions on supporting chimney in attic? John Andrews Masonry 6 06-10-2009 08:47 PM
Dangerous Chimney Dilemna The Boss Masonry 27 04-25-2009 09:35 PM
Metal chimney replacement trade Construction 5 04-06-2009 01:35 PM
Questions About a No Good Chimney Bruce Masonry 11 01-02-2007 12:46 AM
