Negative Pressure Problems
Old 01-01-2007, 02:45 PM   #1
Viper's Avatar
Trade: Jack of all trades/Master of none!
We are suppose to install pool equipment for an indoor pool in a mechanical room just off the swimming pool area indoors. The pool and mechanincal room are heated with radiant floor heat and a closed combustion boiler.
The problem is....besides the dehumidification unit they have, they also have an exhaust unit that is in place to keep constant negative exhaust pressure on the pool building to keep moisture from penetrating the strcture and keep the concentration of corrosive chemicals to a minimum.
The pool equipment includes a heater that is open combustion. I see a definate back draft problem here.
If we bring in fresh air, they will lose the negative pressure.
I don't see any way to make this work.
Any suggestions?
Viper is offline
Old 01-01-2007, 03:28 PM   #2
mdshunk's Avatar
Re: Negative Pressure Problems
Locate that equipment with atmospheric burners in a mechanical room, seperate from the pool room.
mdshunk is offline
Old 01-01-2007, 04:41 PM   #3
Viper's Avatar
I guess an option would be to build a wall in the mecanical room where the pool equipment goes and seal it off from the rest of the area(negative pressure area).
Then fresh air inlet wouldn't be problem. Not sure if this will work with the space. We'll have to go back and take a look at the space.
Viper is offline
Old 01-01-2007, 04:56 PM   #4
Viper's Avatar
Come to think of it, I don't see any reason the whole mechanical room couldn't be sealed off from the pool room. It should only take a good exterior door. Maybe I'll see what they think of the idea since no door is in place yet, I have no idea what is planned to be used.
Viper is offline
Old 01-02-2007, 02:20 PM   #5
POOLMANinCT's Avatar
had considered a heat pump?
POOLMANinCT is offline
Old 01-03-2007, 10:19 PM   #6
Thoroughbred Mopar Man
#CARRIERMAN's Avatar
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi Viper
I would have to side with mdshunk on this one. The only other option would be to find a closed combustion pool heater. I am not sure if the Dunkirk Q95 can be used for this application or not. It is one of the few boilers that is sealed combustion.
Good luck
Rusty
#CARRIERMAN is offline
Pressure washing 2300 sf concrete pitterpat Pressure Washing 13 09-28-2010 08:16 PM
advice on low pressure well problem 72chevy4x4 Plumbing 0 07-16-2007 07:54 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
Solving Problems dayspring Off Topic (Non Trade) 13 06-15-2006 08:45 PM
Carrier Pressure Switch Problems KMH HVAC 4 10-02-2004 11:00 AM
