#21 | |
Trade: H.v.a.c.
Re: Need Furnace Expert - Goodman FurnaceQuote:
I can understand how a cracked h.e. would trip the limit switch, but not how it would attribute to excessive condensate in the inducer housing. By the way, I have to give you props on the advise on using a magnahelic for detecting a leak on the h.e.. Pretty clever. |
#22 |
Trade: hvac repairman
im not sure about goodman , but with armstrong furnaces the control board takes care of the fans and the gas valves controls the ingnition! it almost sounds to me ,you have a high resistance connection ! first and most important ! shut off power ! clean and tighten each and every wire connection ! restore power and try furnance ! if that does not work ,remove flue pipe for a one minute test ,if furnace runs fine you know were problem is! thanks aircon1
#23 |
Glazier
Trade: Commercial & Residential Glazing
Just a thought guys... I know that when Ducane made an update to thier inducer motor housing there was a problem with a proper seal between the PVC pipe and the housing. The fix was to get high temp sealer in the channel where the PVC pipe seats itself and let it set a couple hours to cure a bit. Fixed the problem of the condensate. Happy troubleshooting.
| Quality of Payne furnace ??? | Home Pro | HVAC | 45 | 03-30-2010 10:10 PM |
| Goodman 80% furnace brand new won't start | Hguy | HVAC | 21 | 03-29-2008 12:05 AM |
| Goodman Furnace won't ignite | RocMods | HVAC | 6 | 03-16-2005 10:34 AM |
| Goodman Gmp075-3 Burner Intermittant | DMC | HVAC | 1 | 03-06-2005 04:54 PM |
| need info on a goodman gus 075-3 older 90% furnace | haank | HVAC | 0 | 09-29-2003 11:02 PM |
