Need Air Exchanger?
Old 04-12-2009, 09:38 AM   #1
hurtlocker
nailkiller1's Avatar
Trade: homebuilder remodeler carpenter
Need Air Exchanger?
my brother in law is building a home
1 level 1500 sq feet
does not want to spend the money on air exchanger
would a couple bath fans on timers keep the humidity level down
carpenter looking for any options
northern mn
nailkiller1 is offline
Old 04-12-2009, 09:49 AM   #2
beenthere's Avatar
Trade: HVAC
Re: Need Air Exchanger?
During the winter, yes.
During the summer, probably not.
Where will the fresh air be coming from.
beenthere is offline
Old 04-12-2009, 10:01 AM   #3
hurtlocker
i thought into mech room
but could be anywhere
will i need more than one
Old 04-12-2009, 02:14 PM   #4
beenthere's Avatar
Trade: HVAC
Depends.
How many CFM is the range exhaust hood.
How many CFM are the bathroom fans.
Remember. All fresh air you bring in needs to be either heated or cooled to room temp. So if you just bring in unconditioned air.
Its best to bring it into the return of the forced air system. So that it is spread out amount all the rooms.
That way, you don't notice the cold or hot air you bringing in as much.
Cracked Heat Exchanger SIDrywall HVAC 6 02-17-2009 03:31 PM
Flat plate heat exchanger genecarp Plumbing 2 11-24-2008 10:09 PM
heat exchanger Bone Saw Tools & Equipment 0 10-29-2008 11:40 AM
Heat Exchanger Problem with Hayward Pool Heater jtc1062 HVAC 2 10-22-2007 10:13 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 04:38 PM
