Need Air Balancing Tips
Old 11-10-2008, 10:27 PM   #1
deer3's Avatar
Trade: hvac
so i do commercial hvac service calls and tomorrow i am going into a commercial space to do some air balancing...basically the situation is that the building is one story 2 rooftop units. when you stand on the floor lets say the temp is 20 degrees celsius but when someone gets on a ladder the temperature up at the height of the 10 foot ceiling is somwhere closer to 30 degrees celsius so a 10 degree temp difference....now its been a while since i have done any air balancing so if anyone can refresh my memory it would be greatly appreciated....basically i was going to go in there tomorrow and either add more air return grills in the ceiling or move a few to better suited locations...any ideas or suggestions would be greatly appreciated
deer3 is offline
Old 11-11-2008, 03:31 PM   #2
kennzz05@yahoo.'s Avatar
Trade: hvac
Re: Need Air Balancing Tips
aside from ceiling fans dont think theres much you can do other than installing low returns which probably isnt an option either heat rises im sure the system works great for a/c
kennzz05@yahoo. is offline
Old 11-11-2008, 06:38 PM   #3
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Well not being a certified balancer myself I'll take a shot. Check the plate on the unit and see what kind of cfms it pushes out, then check the size of the ductwork with a ductulator and see if it will provide the necessary cfms in and out. Then take readings with a balometer and see what it is doing. Once you know what it is supposed to do and what it is doing you can figure out if it needs something changed.
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline
Old 11-11-2008, 06:44 PM   #4
A nonprofessional observation.
It always helps stratification
if they will just let the
air handler run continuously.
neolitic is offline
Old 11-11-2008, 06:47 PM   #5
genecarp's Avatar
stratification/ductulater/balometer.
genecarp is offline
Old 11-11-2008, 06:49 PM   #6
I wouldn't bring it down to just an airhandler, I think constant flow is always a more even temperature change, furnace, RTU, a/h, or hotwater system. Keep the pumps and fans running.
Old 11-11-2008, 06:51 PM   #7
OH YEAH, dealing with duct work and airflow is much more complicated than shooting a few staples through a shingle or a few scews into a piece of sheetrock.
Just one of the facets of HVAC work that seperates the mechanics from the hacks and attic butchers.
Old 11-11-2008, 07:05 PM   #8
genecarp's Avatar
[quote=MechanicalDVR;532231]OH YEAH, dealing with duct work and airflow is much more complicated than shooting a few staples through a shingle or a few scews into a piece of sheetrock
Dont forget, we also have to get technical when pulling out rusty nails, and sanding pine.
genecarp is offline
Old 11-11-2008, 07:09 PM   #9
[quote=genecarp;532260]
Hmm, from what I see on the DIY channel it looks like anyone can do it.
Old 11-13-2008, 09:58 PM   #10
mo-flo's Avatar
Trade: hvac
high supply=low return,low supply=high return....i mainly concentrate on the living/working area like 5-6 ft. from floor and not worry so much about what's going on at ceiling level....ain't nobody gonna be up there anyways.
mo-flo is offline
Old 11-13-2008, 10:04 PM   #11
Hot at the ceiling usually means cold
on the floor.
Tell the sales girls in skirts that
it doesn't matter.
neolitic is offline
Old 11-13-2008, 10:12 PM   #12
mo-flo's Avatar
Trade: hvac
that's why you pull the air across the 5-6 ft. by floor with supply and return placement...
mo-flo is offline
Tips for paving a small area. ruskent Excavation & Site Work 26 11-17-2008 10:15 AM
Meeting with a builder in the AM, any tips? ruskent Marketing & Sales 23 11-07-2008 10:18 AM
Tips for pouring a 24' x 24' slab HJConstruction Concrete & Paving 10 04-13-2008 03:43 PM
Recording studio construction tips CNC General Discussion 4 03-13-2008 12:41 AM
