Millivolt Stats
Old 04-07-2007, 08:12 PM   #1
mdshunk's Avatar
Millivolt Stats
What happens when you use a T87 style stat on a millivolt system? I've seen them installed on millivolt systems before, and I always wondered how they managed to set the anticipator. Got any input on stats for thermopile systems?
mdshunk is offline
Old 04-07-2007, 08:55 PM   #2
POOLMANinCT's Avatar
Re: Millivolt Stats
if im not missing something continuity is continuity...
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 04-07-2007, 09:00 PM   #3
mdshunk's Avatar
Re: Millivolt Stats
Until you add the resistor that is necessary for a heat anticipator....
mdshunk is offline
Old 04-07-2007, 09:05 PM   #4
Re: Millivolt Stats
you got me.... i forget theres more to life than pool equipment..
sometimes i know enough to be dangerous or enough to hire somebody
Old 04-07-2007, 10:44 PM   #5
PIPES's Avatar
Trade: Plumbing and heating
Re: Millivolt Stats
MD, the T-87 is just the number for the style. You can buy the for different needs millivolt/24 volt , it's just a different suffix. T-87 ....
PIPES is offline
Old 04-08-2007, 11:02 AM   #6
acefurnacefxr's Avatar
Trade: HVAC
Re: Millivolt Stats
My favroite milivolt stat is the WR 1f86-344
Our 44 th is the best one yet..........
acefurnacefxr is offline
Old 04-28-2007, 09:38 AM   #7
hf05's Avatar
Trade: hvac tech
Re: Millivolt Stats
t-87 is a 24 volt stat{as u know].what will happen on a millivolt system is it will work for awhile then become intermittent.as the generator gradually loses millivolts and because everthing is in series the resistence from the anticipator will start to cause nuisance no heats.usually up and down on the stat will bring it on,with the customer scratching their heads.24 volt stat may be used with add on isolation relay controling primary control.
hf05 is offline
Old 05-11-2007, 08:18 PM   #8
Thoroughbred Mopar Man
#CARRIERMAN's Avatar
Trade: Railroad Conductor/ Ex Hvac Service manager
Re: Millivolt Stats
Hi Md
You know I have to through in my 2 cents. When using a 24 volt stat on a millivolt system (not reccomended). All you have to do is short the heat anticipator across the pins,this removes the heat anticipator out of the equasion most thermostats have this ability. But for accuracy sake I wouldn't waste my time, but in a pinch it can be done. As we all know when you through excessive resistance on a millivolt generator, we have continuous callback problem due to lack of reliable heat.
Good luck
Rusty
Character is doing the right thing even when no one is looking. Intelligence is understanding and practicing the meaning of character.
#CARRIERMAN is offline
Good web stats software CreativePainter Technology 17 02-08-2011 02:48 PM
Some stats for our industry that bode well Mike Finley Business 8 06-03-2007 10:36 AM
online phonebook vs print user stats help? the_turd_man Marketing & Sales 1 03-05-2007 10:02 AM
My Service magic stats AHS Marketing & Sales 9 03-29-2006 08:08 PM
