Luxaire Furnace Shuts Down
I am having a problem with my luxaire 93% furnace. Every morning from about 4:00
a.m. till about 8:00 a.m. the furnace fan will start normally, the igniter will glow, the burner will fire up for about 5 sec. then it will shut down. after about 15 sec. it will start back up with its cycle and this time the burner will run for about 15 sec. then shut down. the third or forth time it does this it will stay fired and run normally through its cyle. Other times of the day it seems to run normally. I have replaced the igniter and checked that the air intake and exhaust pvc pipes are clear. Any idea's-thanks |
#2 | |
The Doctor is In!
Trade: HVAC owner
Re: Luxaire Furnace Shuts DownQuote:
NICKTECH
make sure the flame engulfs the sensor, check the maniflod gas pressure with a manometer. it should 3.5" water column.
| Quality of Payne furnace ??? | Home Pro | HVAC | 45 | 03-30-2010 10:10 PM |
| Goodman 80% furnace brand new won't start | Hguy | HVAC | 21 | 03-29-2008 12:05 AM |
| Furnace Cycling | reddog | HVAC | 9 | 11-04-2005 09:31 PM |
| Luxaire Furnace G8T13020uhd11 cold air problems | equinta | HVAC | 5 | 03-20-2005 10:29 PM |
| Luxaire furnace "puffs out" | Bman8950 | HVAC | 0 | 12-27-2004 01:21 AM |
