Luxaire Furnace "puffs Out"
Old 12-27-2004, 01:21 AM   #1
Bman8950
Guest
Bman8950's Avatar
Posts: n/a
I have a year old Luxaire Furnace Model G8T 80 % efficient. Recently, whenever the furnace cycled on again, the jets would puff out immediately after igniting. It would try this 3 times before shutting down. It is only happening radomly, and never while the furnace is operating and blowing heat. My solution has been to turn the unit off for ten minutes and then try again. This works, but only for a short time. The error light has blinked 7 times whenever this happens. According to the manual, this could be a number of problems...low gas pressure, faulty gas valve, faulty hot surface ignitor, or a burner problem. Since original installer moved, will have to call a new tech. Would like any ideas to check for before doing that. Only thing left for me is to change batteries in thermostat which I will do tonight. Any help would be greatly appreciated.
BMan
Quality of Payne furnace ??? Home Pro HVAC 45 03-30-2010 10:10 PM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Maybe it's a good time to upgrade furnace ron schenker HVAC 4 03-02-2007 12:11 PM
Luxaire Furnace G8T13020uhd11 cold air problems equinta HVAC 5 03-20-2005 10:29 PM
luxaire furnace shuts down gerry m HVAC 3 03-04-2005 07:47 PM
