Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 02-04-2004, 11:48 PM   #1
Unregistered
Guest
Trade:
Posts: n/a
Angry Luxaire Furnace not lighting
I am having problem with my Luxaire furnace it will not light it only blows cold air. If I put my hands under the exhaust duct when I restart it it will light.
Old 02-05-2004, 06:14 AM   #2
Bjd
Trade:
Locate the control board, and find the LED that is going to tell you a flash code.
Once you have this we may be able to help you in some way.
Bernie
Bjd is offline   Reply With Quote
Old 02-05-2004, 09:31 AM   #3
Unregistered
Guest
Trade:
Posts: n/a
Bernie
How and where do I find the LED it is an outside rooftop unit.Rhonda
Old 02-05-2004, 08:53 PM   #4
Trade:
My money is on a bad smart valve. Rhonda you will have to call for a professional diagnosis.
Steve Wiggins is offline   Reply With Quote
Old 02-16-2004, 10:11 PM   #5
Unregistered
Guest
Trade:
Posts: n/a
I have had the worst of times with my Luxaire model (matter of fact, had the same problem just moments ago...about a weekly chore). I've gotten pretty good at taking the burners out, using a flexible wire brush that fits inside and blowing them out. I finished our basement off a year ago, and I think dust may have settled in the control. But, after cleaning the blowers out, it seems to light regularly...for the next week or so. I did notice tonight that the seal around the intake by the fan motor was damaged and was blowing air down towards the first burner. After cleaning the blowers and placing a finger over that draft, it lit right up. So, advice, clean the blowers (you can do this yourself). If that doesn't work, check for internal drafts.
You also mentioned that it won't light. I assume that the ignitor is firing. If not, it might be as simple as replacing the ignitor...
Old 02-17-2004, 05:16 AM   #6
Bjd
Trade:
Tea the was Honeywells claim to fame, the "SmartValve System" what a real piece of junk. Just the igniter and poilet is around $50.00.
Bernie
Old 06-17-2004, 09:07 PM   #7
Unregistered
Guest
Trade:
Posts: n/a
Furnace blower
have you ever had the blower fan stop working ? I assume the motor may be burnt out but I have not checked it . I had a similar problem with the ignighter and it was just the sensor had come loose.
peter.schmitz@telus.net
Quality of Payne furnace ??? Home Pro HVAC 38 09-29-2009 09:42 AM
Area lighting for Pipe Guy mdshunk Electrical 5 01-26-2009 02:25 PM
Residential General Lighting Circuits toastermaker Electrical 11 02-26-2006 01:04 AM
Landscape Lighting NightScenes Landscaping 0 01-11-2006 06:58 PM
Luxaire furnace "puffs out" Bman8950 HVAC 0 12-27-2004 01:21 AM
