Low Voltage, Goodman AH
Old 03-25-2009, 10:21 AM   #1
newfy's Avatar
Trade: building/remodeling
Have Goodman AEPF variable speed air handler & GSC condensor, 11 wires on air handler low voltage,what wires to themostat (3 wire) & condensor (2 wire)?
Air Handler wires: Yellow
brown these 4 maked condensor
black
red
R
G
Blue
Purple
Brown these 6 maked Therm
W
Y(orange) Heat
Thanx
newfy is offline
Old 03-25-2009, 11:07 AM   #2
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
Re: Low Voltage, Goodman AH
sounds like its a heat pump AH. if its for cooling only refer to the notes on p 8.
http://www.goodmanmfg.com/Portals/0/pdf/SS-GAEPF.pdf
NickTech is offline
Old 03-25-2009, 12:47 PM   #3
newfy's Avatar
Its not a heat pump, straight cooling with a variable speed air handler.
newfy is offline
Old 03-25-2009, 08:43 PM   #4
flashheatingand's Avatar
Trade: H.v.a.c.
The wiring diagrams should be on the panels of the appliances. Where did you get the furnace from?
flashheatingand is offline
Old 03-26-2009, 08:43 AM   #5
newfy's Avatar
Diagram was pasted on side wall of handler, can not see, was called in after the fact to wire. Pulled up the AEPF wiring diagram on p.8 off the Goodman site, for cooling only, the condensor getsYcon(Y) and C(Blue) as is note 4; then the thermostat is connected to Y/Y2(Y),R, and G?
Thanx for the input.
newfy is offline
Old 03-28-2009, 06:16 AM   #6
beenthere's Avatar
Trade: HVAC
Its factory set up for a slow ramp up.
So you won't be able to check charge right untill the blower goes to full speed after 8½ minutes.
unless you remove the factory jumper. Its in the notes abot the jumper.
beenthere is online now
Low Voltage in the outer Chicago Area dgregait Low Voltage 5 09-09-2011 09:12 AM
High Voltage vs Low Voltage Lights robertc65 Outdoor Lighting 16 04-04-2011 06:26 AM
Goodman Gas furnace propertyone HVAC 3 02-22-2009 07:36 AM
Voltage Drop and Conductor Size TinkerGA Electrical 10 02-11-2009 12:29 AM
low voltage tech tools slowforthecones Low Voltage 13 10-21-2008 08:12 AM
