Loud Bang Noise
Old 10-31-2004, 08:27 PM   #1
Guest
Guest
helpme's Avatar
Posts: n/a
Loud Bang Noise
I have a furnace service with the loud bang noise.the customer said it happends one or twice a month. I couldn't find what causes this proplem.Please help me if you have this experience.Thank you.
Old 10-31-2004, 09:41 PM   #2
Grumpy's Avatar
Rewards Points: 2,000
Re: Loud Bang Noise
Perhaps your customer has a family member who keeps hitting their head on the duct work in the basement.
Grumpy is offline
Old 10-31-2004, 10:02 PM   #3
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Rewards Points: 150
Re: Loud Bang Noise
I was thinking along the line of static pressure popping the ductwork but I like Grumpys answer better!
HVAC Doc is offline
Old 11-01-2004, 12:06 AM   #4
Grumpy's Avatar
Re: Loud Bang Noise
LOL I have a brother and a real good friend who are both in HVAC and I keep telling them they need to stop bye here but neither ever does
One thing's for sure... I know more about hvac than the average roofer!
Grumpy is offline
Old 11-01-2004, 04:45 AM   #5
Bjd's Avatar
Rewards Points: 250
Re: Loud Bang Noise
Could be a delay in ignition?
BJD
Bjd is offline
Old 11-06-2004, 11:53 AM   #6
Mechanical Mind's Avatar
Trade: hvac tech
Re: Loud Bang Noise
Where they are when they hear the noise can be helpful in determining what is "actually" causing the noise.
For instance, if they hear the noise in every room in the home equally... chances are that it is the ductwork itself popping.
However, if they hear the noise down near the furnace only... they could be hearing delayed ignition or even a blower engaging (if old belt-drive).
Mechanical Mind is offline
Old 11-06-2004, 02:24 PM   #7
Teetorbilt's Avatar
Re: Loud Bang Noise
Mechanical Mind, Please read the advertising policy, I believe that you are selling software on that site.
Teetorbilt is offline
Old 11-07-2004, 06:29 AM   #8
Trade: hvac tech
Re: Loud Bang Noise
No Sir. I am not selling anything. That is just my homepage. Another place that I hang out. And I didn't put it in link format. Just text.
Old 01-30-2005, 02:10 PM   #9
zoeyarn's Avatar
Re: Loud Bang Noise
Check the burner orifices very carefully- spiders like to build nest and plugs burner where it comes out of the maifold- flame on that burner may look alot lower than the others and if this is the burner that is nearest the spark or hot surface ignitor [or standing pilot] the gas will build up in the other chambers before this burner lights- then you have what amounts to a small explosion. Clean this burner orifice out with a thin wire
Cheers
JSA
zoeyarn is offline
Old 02-16-2005, 10:37 PM   #10
I'm just stirring the:
CGofMP's Avatar
Trade: .
Rewards Points: 250
Re: Loud Bang Noise
This used to happen from time to time at my father's house. The heater was in the laundry room which was where the dogs slept.
Every once in a while there would be an explosion like sound from the heater.. you know what is coming right?
Nobody knew what it was, always happened without ryme or reason and only when the heater came on...
Turns out that the little bits of doghair and dust would settle into the heater and somehow plug up the works just a tad. The 'explosions' would produce 1.5 feet of flame for just an instant.
Cleaning the heater well, and being more consistent about cleaning the floor in the laundry room solved the problem.
CGofMP is offline
Old 02-17-2005, 11:56 PM   #11
NICKTECH
NickTech's Avatar
Rewards Points: 250
Send a message via AIM to NickTech Send a message via MSN to NickTech
Re: Loud Bang Noise
gremlins.....;definately gremlins
NickTech is offline
Help - how to reduce noise at heating vent j97chung HVAC 3 01-03-2007 09:08 PM
Tapping noise ... RobertWilber Electrical 3 09-07-2006 06:22 PM
Loud squealing noise from pipes ChuckEA Plumbing 3 08-19-2006 04:20 PM
Furnace-gas forced air- high pitched noise saturn711 HVAC 3 03-25-2006 08:52 PM
