Trade: Painting and wallcover
Looking For Ideas For Insulating Craw Duct Work.
Be gentle a painting contractor looking for some ideas. NW Ohio House is on a crawl. Typical 1950 ranch with metal duck work. Or am I pissing in the wind by doing this. As I said looking for idea. and the pros and cons
Thanks David Veith David Enterprises |
Re: Looking For Ideas For Insulating Craw Duct Work.
Insulate the crawl space,
not the duct work. Vapor barrier on the floor, 2" styrofoam on the walls, R-13 - R-19 in the joist pockets and on the rim joist. Keeps the plumbing and floors warm. The heat loss is..... into the house!
Dr Heat
Trade: hvac
is the crawl ventilated?
Can you get to both sides of the duct? what kind of floor is in the crawl? |
Dirt floor with vapor barrier 2x12 rafters and yes I can get around the main trunk line. Floor is mainly insulated.
David Veith |
#5 | |
Re: Looking For Ideas For Insulating Craw Duct Work.Quote:
your climate, do what you will. http://apps1.eere.energy.gov/consume.../mytopic=11480 http://forums.jlconline.com/forums/s...er+crawl+space http://forums.jlconline.com/forums/s...te+crawl+space http://forums.jlconline.com/forums/s...te+crawl+space http://www.buildingscience.com/docum...s/?full_view=1
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 01-17-2009 at 04:33 PM. |
Trade: sparky
neolitic has a good point but 2 things with that I can think of;
1. you have not stated if this is a vented crawlspace or not. If it isn't, have you taken a radon check to be sure you do not have a radon problem and if you are considering sealing the crawlspace, do not cause yourself a problem with radon buildup if it is there. 2. the crawlspace acts as a buffer. By making that buffer part of the heated/cooled area, you are increasing the temp differential between any 2 areas which results in a faster heat loss. Not sure of the overall result but something to think about. If you want to insulate the ducts, use duct insulation or duct wrap. Here is a pic but I don;t know how to resize so I will only provide the link. http://news.thomasnet.com/images/large/019/19284.jpg |
Vented crawls in our climate
are a nineteenth century idea. This is the twenty first century!
Dr Heat
Trade: hvac
If the crawl is vented insulate the duct if it is not vented insulate and condition the crawl.
the best way to insulate duct is to wrap it national building code calls for a min R5.7 I use 2" fiberglass batts they come 47" wide and 50' long roll you can get other sizes but that is the standard. Begin buy sealing all the connections with mastic or mastic tape code calls for 181 tape but you can get the same product without the label cheaper. Do not use duct tape or silicone as these will not stick. Pre cut your insulation take the total top + sides + bottom then add 6 " for an overlap. You will need to buy a stitcher (Aro p32 stapler) wrap the duct cutting around the takeoffs lapp to the corner and fold 2" under so you can stich the foil wrap together. Now tape the ends all the way around the duct. This is an excelent diy project as it requiers time and lots of it but no particular danger of doing it wrong. Also you can save a butt load over having my crew do it. A recent job: 3' crawl wraped 50' of trunk and 200' of branch. Took 3 days $200 in matterial. Job cost $2,700 so if you can crawle around and do it you can save $$$ This is a two man job you really need one man on each side of the duct. If you do not seal the duct you will endup with a balloon
Dr Heat
Trade: hvac
Re: Looking For Ideas For Insulating Craw Duct Work. |
#10 | |
Trade: sparky
![]() I would suggest sealing it but just be sure the radon is not a problem. |
Trade: Electrical & Carpentry
Do not insulate the duct work as Neolitic said. Insulate the perimiter of the crawl space only. If anything install a diffused outlet from your duct work into the crawl space-keeping it & your floors & house warmer for the winter and your crawl space dryer. It will be more cost efficient... Ventilate it in warmer weather......... Mike
The crawl is ventilated. What good the Half dozen or so vent do is a another ? that I don't plan to go after.
David Veith |
#13 | ||
say to insulate the duct work? Quote:
#14 | |
with central heating and cooling. (19th century = 18xx)
I like Green things
Just 'cause you wasn't there......
| extra work questions for the pros | A.W.Davis | Business | 27 | 01-03-2012 04:14 PM |
| anyone have a copy of a "ticket" for work performed | AintNoFun | Business | 6 | 10-05-2008 09:31 PM |
| Need help on paper work. | KB construction | Business | 0 | 04-24-2008 05:03 PM |
| Another silver lining in these dark clouds | Mike Finley | Business | 0 | 04-02-2008 03:36 PM |
| Western PA subcontractor looking for work | HallamContract | Help Wanted or Looking For Work | 0 | 03-25-2008 06:29 PM |
