Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 12-30-2006, 08:13 AM   #1
Trade: homeowner
Question Lennox Pressure Switch Trouble?
No heat. If you turn the main switch off and back on the inducer motor runs briefly. Then you pull off one of the wires from the pressure switch. You have to wait about five minutes and the inducer blower will come back on. At that point if you reconnect the wire to the pressure switch, the furnace will run until the thermostat is satisfied. This process has to be repeated every time heat is wanted. does this sound like a bad pressure switch? Thanks! John
Glock23 is offline   Reply With Quote
Old 01-03-2007, 10:25 PM   #2
Thoroughbred Mopar Man
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi Glock23
The easiest way to figure this out is to look at the board and see what code its giving you. It almost sound like the switch is sticking closed. If you pull the hose off of the inducer, blow lightly and suck lightly on the hose you can sometimes break them loose. But the permanent fix is to replace the switch.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
High Pressure Control Reset Switch bjg5240 HVAC 5 04-23-2007 04:27 AM
Irrigation pump pressure switch mdshunk Landscaping 10 12-04-2006 09:39 PM
smart light switch circuit toastermaker Electrical 7 12-07-2005 11:45 PM
Draft inducer vs. pressure switch vs.? arctic trooper HVAC 3 03-15-2005 08:29 AM
