Invisible Basement Ductwork
Old 09-25-2009, 01:31 PM   #1
Red Dot D+B
Dog Gone's Avatar
Trade: Licensed General Contractor
Dealing with low basement height clearances is a common problem for many remodelers. Aside from the occasional beams, HVAC supplies and returns are often the biggest obstical. Traditionally, we've minimized the ductwork's intrusion by using shallower and wider ducts and creating ceiling soffits.
What would be the problem with constructing the Supply line so that is has a short down-vent immediately leaving the furnace and running supply along the FLOOR hiding ducts under window seats, etc.
Seems like it would create some ininital resistance making blower work harder and consuming more power - but if sealed well wouldn't this function normally?
Dog Gone is offline
Old 09-25-2009, 07:36 PM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Re: Invisible Basement Ductwork
The problem is that the air will gyrate too close to the furnace. As a result, it is highly possible that the furnace will over heat during the winter, and possibly the coil will freeze during the summer. I like the air to shoot straight for at least 2 feet before going into a 90. However, field conditions don't always allow this. The closer the off-set from the furnace, the greater the risk of air-flow problems
Go Hawks!!
flashheatingand is offline
Old 09-26-2009, 06:10 PM   #3
beenthere's Avatar
Trade: HVAC
You would have to make the duct bigger to allow for the extra turns, and the longer length.
You also would add a large cost to the install, in those applications that the joist are panned for returns. Since now they would have to be hard piped.
The real easy solutions are.
A: Builders/architects design the homes to have the duct work run in the conditioned area of the home..
B: Make the basement 9' high.
beenthere is offline
Tags
ductwork, hvac
The perimeter drain question- basement bnentrup Excavation & Site Work 7 08-14-2009 11:28 AM
Return Grill in the Basement orson HVAC 7 10-03-2008 12:01 AM
Basement bathroom Input requested guyute65045 Plumbing 7 09-14-2008 09:43 PM
HELP! Basement floor disaster Profiter Construction 5 07-11-2006 09:01 PM
