Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 06-21-2004, 08:20 AM   #1
Awaiting Email Confirmation
Trade:
Interior A/C unit freezing up?
I don't know a whole bunch about this unit. It's 8 years old, is a heater/air conditioner. It's in a small double wide mobile home (rental unit). After the A/C has been running for about 7 or 8 hours it starts blowing warm air. Take the front of the A/C unit off and the interior unit is covered in ice. Does anyone know what would cause this??
Kim1181 is offline   Reply With Quote
Old 06-21-2004, 12:01 PM   #2
The Doctor is In!
HVAC Doc's Avatar
Trade: HVAC owner
Good chance (and most likely with the type of unit it is) your a-coil is dirty causing a restriction in airflow. Also could be a plugged filter or low on charge.
HVAC Doc is offline   Reply With Quote
Old 06-25-2004, 08:28 AM   #3
Trade:
Think we got it figured out.
Had a fellow volunteer firefighter (A/C man) come and check out the unit for us. Every thing was clean and charged. Started looking into the wiring... looks like it might have been caused by the thermostat. Installed a new one yesterday evening and left it running all night (nobody living in the house right now). I haven't heard what the verdict is this morning. Sure hope this takes care of it though.
Old 06-26-2004, 04:59 AM   #4
Bjd
Trade:
I do not think a thermostat is your problem if its freezing up, I would go back to the Doc ideas and check filters and coils also check to make sure the fan is running at its max speed and just be sure all of the registers are fully open.
Be sure the condensate drains are also working, and are clear of obstructions.
If alll of this proves to fail to solve the freeze, you need a charge
Bernie
Bjd is offline   Reply With Quote
central unit stolen williefb General Discussion 2 07-30-2007 07:29 AM
outside unit A/C Home Serve HVAC 5 06-07-2007 10:30 PM
Central Unit Stolen williefb General Discussion 23 04-14-2007 11:27 PM
Used the mini skid today-Toro Dingo tracked unit IHI Tools & Equipment 5 06-13-2006 08:22 PM
New Central Air Unit for Ranch House Robie HVAC 9 03-25-2006 10:01 PM
