Installing Exhaust Fan Into Short Space...
Old 10-04-2017, 06:25 AM   #1
RookiePlumber's Avatar
Trade: HVAC install and repair
Rewards Points: 260
I've got a ~ 6" square duct that I need to fit an exhaust into. The duct runs vertically for 3 1/4" before it starts to turn 90 degrees.
I was going to install the Broan 673 vertical discharge fan into the duct but with the air damper blades extended the fan has a total vertical height of 7". Plus the electrical connections are on the lower half of the fan.
A not so desirable alternative is to build a custom plywood box and have the lower half recess into the bathroom.
I'd prefer to spend the money and get an out of the box solution.
Thoughts?
RookiePlumber is online now
Old 10-05-2017, 02:21 PM   #2
Designer/Contractor
Rio's Avatar
Rewards Points: 1,832
Re: Installing Exhaust Fan Into Short Space...
Maybe something along these lines, where the fan unit is not at the ceiling but down along the ducting somewhere
Rio is online now
The Following 2 Users Say Thank You to Rio For This Useful Post:
RookiePlumber (10-06-2017), rselectric1 (10-05-2017)
Old 10-05-2017, 03:55 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,977
Multi-unit building?
MarkJames is offline
Old 10-05-2017, 04:11 PM   #4
Designer/Contractor
Rio's Avatar
That was just an example of an inline fan, sure they have single duct designs also.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Old 10-06-2017, 07:45 AM   #5
Rewards Points: 260
Yeah I'm on the top floor.
Old 10-16-2017, 02:02 PM   #6
Rewards Points: 260
Finally got around to working on this project.
I peeked into the space where my vent enters the main duct by removing a light fixture.
Any ideas on how to cleanly adapt a 90 degree elbow to fit my vertical fan?
Maybe a taller 90 degree elbow?
Old 10-16-2017, 04:56 PM   #7
MarkJames's Avatar
Then you likely don't need one. There's a fan on top of the building.
RookiePlumber (10-16-2017)
Old 10-16-2017, 05:12 PM   #8
Rewards Points: 260
Iím on the top 2 floors. I have the 4th and 5th floor. This fan is for the fourth floor. It definitely needs ventilation as the air is so stale.
Old 10-16-2017, 08:46 PM   #9
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 2,063
Your screen name says you're a plumber, yet you list your trade as HVAC.
So which is it? Seems like even a plumber should be able to solve this on his own, let alone a HVAC guy...
Tinstaafl is online now
Old 11-05-2017, 07:25 PM   #10
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
I was getting confused by his multiple "how do I?" tile postings when I found one in the plumbing section about glass. It was on a job for his girlfriend and turns out a lot of his posts are "how do I?" posts about bathroom work involving plumbing/tile...and here, hvac.
I didn't realize that until I looked at his post history to find where you moved that shower glass subject and saw all of his posts were questions and I'd not be surprised that's all he's done here, start threads with questions.
"Nobody is more inferior than those who insist on being equal" -Friedrich Nietzsche
Krok is offline
Plastic on ceiling in basement (unconditioned space) zesone General Discussion 20 05-04-2015 08:10 PM
An Elevator To Space Is In The Works In Japan Tquentin Off Topic (Non Trade) 35 02-28-2012 07:34 AM
need advice on installing vinyl surround Laketahoedan Kitchens & Baths 3 10-07-2010 06:46 AM
Space between TracRac and tool box? Clydesdale Vehicles 4 02-06-2010 09:36 AM
insulating floor truss in crawl space AustinDB Construction 8 08-22-2008 07:54 AM
