Industrial Chiller Plant Operator Stummped By Rheem
Old 01-16-2009, 09:26 AM   #1
zoli's Avatar
Trade: Chiller plant operator
Hi all
I am having problems with my rheem unit and need some wiering advice.
I HAVE A OLDER MODEL rcba-4882as21 air handler with a rheem rp7a042jaz heat pump condenser. and a new Honeywell RTH3100 t-stat that i am trying to install ( old t-stat was ripped off the wall by renters )
I have no diagrams as they had faded away.
I am trying to replace the thermostat. If you can help i need to know what color wires are what inside the air handler i have a Black/white black/green purrple red brown in the air handler...
on the t-sat i have E AUX Y G O L R B C
outside on the heat pump i have three wires going in the unit a red a yellow and a blue
If you have any ideas please e-mail me at zolkat (@) earthlink.net
Thanks
zoli is offline
Old 01-16-2009, 09:45 AM   #2
Handle It!
MALCO.New.York's Avatar
Re: Industrial Chiller Plant Operator Stummped By Rheem
Jumper.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 01-16-2009, 10:27 AM   #3
zoli's Avatar
unit does not call for jumper and if it did where would it go? i dont have rc or rh on stat only r
zoli is offline
Old 01-16-2009, 10:39 AM   #4
Handle It!
Hmmmmmmmmmmm??!!!
How many different wiring options are there? Process of elimination?
Old 01-16-2009, 10:51 AM   #5
zoli's Avatar
well unit is a older rheem heat pump on the AH i have black/white that goes to electric heat, than black/green that goes to fan, got my red = 24 v, than brown = common, and a purrple that according to rheem goes direct to the heat pump... for defrost
on my Honeywelli have E AUX Y G O L R B C
my guess would be as obvious gr/black to G
Red to R
Black/wht to AUX
Brown to C
There is nothing for O = reversing valve..
Any ideas?
zoli is offline
Old 01-16-2009, 12:34 PM   #6
A Smarter Home's Avatar
Trade: Automation and Theater
how many wires do you have at the stat?
A Smarter Home is offline
Rheem FVIR power vent water heaters Sewerologist Plumbing 11 02-19-2009 01:24 PM
Rheem Classic 90 humidifier trouble norcim HVAC 5 11-26-2008 02:12 AM
Rheem Marathon NickTex Plumbing 8 06-05-2008 06:15 PM
problems with Rheem tankless hot water heater configuration? KesslerDweller Plumbing 22 05-14-2008 12:35 AM
