Improper Venting
Old 01-22-2004, 01:09 PM   #1
Unregistered
Guest
Unregistered's Avatar
Posts: n/a
Question
Improper Venting
If the vent does not allow for proper draft - can the inducer be damaged?
thanks.
Old 01-22-2004, 06:35 PM   #2
Steve Wiggins's Avatar
Re: Improper Venting
It's not likely but the tube connected to it could be clogged.
Steve Wiggins is offline
Old 01-23-2004, 05:47 AM   #3
Bjd's Avatar
What type of vent are you talking about?
BJD
Bjd is offline
Old 01-23-2004, 09:56 AM   #4
MK-unregistered
Guest
MK-unregistered's Avatar
Posts: n/a
Post
The metal vent that provides the draft. Runs outside and up the side of the house.
BJD
Old 01-24-2004, 05:42 AM   #5
Bjd's Avatar
Well yea the inducer motor can be damanged if for some reason the B-Vent flue is plugged up or is obstructed by something.
Is the unit venting to the outside from the unit, IE can you see vapor on a cold day exit the top?
BJD
Bjd is offline
Old 01-28-2004, 02:05 PM   #6
Unregistered
Guest
Posts: n/a
thanks for your help. someone doing work on my house - moved the B-vent flue and did not extend it above the roof line (actually only about 3 feet up). due to that the inducer motor was damaged. before "yelling" at the workman I wanted an objective answer.
thanks again.
new carrier furnace owner.
BJD
Old 01-29-2004, 05:48 AM   #7
Bjd's Avatar
sorry we got some guy in trouble
Bjd is offline
Gas Drier Venting ARTSBEST Plumbing 6 03-06-2007 10:58 AM
Marvin Venting Picture Window/ Useless? dougchips Windows, Siding and Doors 3 10-29-2006 10:59 PM
Venting a cape? jkdon Roofing 3 05-10-2006 10:27 PM
Roof venting Geo Roofing 5 04-13-2006 10:14 PM
Water Heater Venting rakes9720 HVAC 4 01-25-2006 07:28 PM
