Ideas For Outside Unit Sound Barrier
Old 11-10-2009, 01:30 PM   #1
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
I received a call today from a client asking for a sound barrier to be constructed around their 2 outside A/C-Heat pumps. Neighbors complaining about the noise while they sit on their patio. Besides a sound blanket over the compressor itself, all I can think of right off is a 3 sided, 6 ft high fence looking barrier with PT plywood behind the fence boards. Any good solutions you have seen??
Thanks,
Steve
BACKWOODS is offline
Old 11-10-2009, 04:50 PM   #2
Remodel & Repair
carolinahandyma's Avatar
Trade: Remodel and Repair Services
Re: Ideas For Outside Unit Sound Barrier
There is a fence like structure that looks like a grill that I have seen before. I will try and see if I can locate it and post the link.
carolinahandyma is offline
Old 11-10-2009, 04:55 PM   #3
Remodel & Repair
Here it is http://www.acousticalsolutions.com/l...he-kiwi-grille I don't have any first hand experience with it. Just found it while researching a similar topic. One thing I have learned about sound proofing is that sound tends to bounce off hard surfaces and is absorbed by soft surfaces.
The Following User Says Thank You to carolinahandyma For This Useful Post:
BACKWOODS (11-10-2009)
Old 11-11-2009, 06:19 AM   #4
beenthere's Avatar
Trade: HVAC
The unit will require a min of 24" clearance between it and the barrier.
May need more. possibly 3'.
The higher the barrier, the more clearance you need. To prevent the unit from drawing its own air back into it. Specially heat pumps.
Keep in mind. That the outdoor unit, moves more air per ton then the indoor unit does. Usually, about 2-1/2 times as much, and sometimes even more. A 3 ton heat pump, may need 3600CFM for the outdoor unit.
Even though the indoor is only moving maybe 1200 CFM.
beenthere is offline
Vapor barrier product suggestions please Dairylander Flooring 1 10-30-2009 01:48 PM
What size unit? MJM HVAC 32 04-07-2009 12:39 AM
Vapor Barrier memetic Construction 16 12-06-2008 02:12 AM
trailer workbench ideas? Mike B Vehicles 3 08-11-2008 01:36 AM
New Central Air Unit for Ranch House Robie HVAC 9 03-25-2006 10:01 PM
