Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 07-18-2008, 03:06 PM   #1
Trade: general contractor
HVAC Retrofit. Options??
I have a client that is looking at retrofitting an existing small apartment block and is looking for options.
It is a concrete block and currently has an old natural gas water boiler system. While he could upgrade to a newer boiler system, he is looking for options that would allow for separate heating bills for the three suites in the block.
Sounds like a complicated job with few options.
Thoughts?
fumbrunner is offline   Reply With Quote
Old 07-20-2008, 07:14 PM   #2
HVAC Tech, NATE certified
Trade: Hvac technician. Boehmer Heating
i've never had to split up a unit, but does the house have 3 gas meters? and is the layout done in a way that you can isolate the radiators or baseboards for each unit? If so you could run 3 small boilers. it would involve disconnecting the mainlines from the larger boiler and piping a new input/output loop for each new unit to connect the existing rads. if its all from one main gas line, and only one gas meter, thats gonna have to be split to bill them accurately. boiler zoning would work, temperature control-wise but it wouldn't separate the bills. But if hes looking to upgrade anyway, just split it up in the beginning and cut to the chase. but i'm not a boiler guru, this is just my humble 2 cents worth.
Best line from a customer "you here for the tune-up? the tank of 22 is in the shed, let me know if you need more."
Verbal is offline   Reply With Quote
Old 07-21-2008, 03:01 PM   #3
Yes, its one gas line right now but I suppose it could be split.
I am not sure if the lines are isolated in such a way that they can be easily split. I suspect not.
I guess there are a few options here:
1. evaluate the possibility of isolating the water lines and installing three boilers
2. upgrade the electrical and install baseboard heating
3. box in cold and hot air returns and run forced air.
None of them look like very good options given the specifics of the building.
His best bet is probably to improve the EE of the building and run a high-efficiency boiler.
Thoughts?
Old 07-21-2008, 07:55 PM   #4
Well if it was my house, i would prefer boiler heat, i think its the best way to go. But the easiest would probably be option 2.
Old 07-22-2008, 10:14 PM   #5
Trade: HVAC Contractor
How about one of the Daikin or Mitsubishi heatpumps with wall mounted indoor units. Units still produce about 80% heat capacity at -20F.
westernhvac is offline   Reply With Quote
Old 07-26-2008, 08:27 PM   #6
Electro-Mech. Contr.
MechanicalDVR's Avatar
Trade: Mechanical Contractor
Thoughts?
What state is it in? Would adding a/c be a plus?
"Injustice anywhere is a threat to justice everywhere" mlk
100% Union and Proud of It
MechanicalDVR is offline   Reply With Quote
Old 07-31-2008, 12:45 PM   #7
We are in Manitoba Canada. A heat pump is not an option. Gets way too cold for way too long up here.
Not really looking at AC options. The tenants just typically use window units.
Old 07-31-2008, 06:05 PM   #8
Trade: H.v.a.c.
Thoughts?
I had a potential client who had a similiar request. I don't know too much about the product (actually, I know nothing about it) but, I should study this matter further because it is not that rare of a request... Nevertheless, what useful information I can provide is: Google sub- meters, natural gas. That may lead you somewhere. There were a few sites that looked interesting, but it required too much reading at the time.
Good luck
flashheatingand is offline   Reply With Quote
Paychex HR Support, or other options? BreyerConstruct Business 4 02-11-2008 01:27 PM
Lots of HVAC questions for 1200 SF new construction Badfish740 HVAC 5 10-02-2007 10:49 AM
Commercial HVAC Reading Material TheRyeCatcher HVAC 3 07-26-2007 07:50 PM
Specialty HVAC tools jpplumbing HVAC 1 08-29-2006 02:17 PM
Building a custom home - HVAC options - could use a bit of help please! loriruthw HVAC 7 07-21-2004 10:56 PM
