Hvac Guys Is There A Difference
Old 08-03-2006, 07:14 PM   #1
MikeT's Avatar
Trade: Remodeling, Home Improvement, Decks, Etc.
Is there a big difference in unit size such as 2.0 2.5 and 3.0 ton units ....
Does a half ton make that big of a difference????
MikeT is offline
Old 08-03-2006, 07:24 PM   #2
jmic's Avatar
Re: Hvac Guys Is There A Difference
I was recently told that the rule of thumb is a ton will take care of approx. 600 sq. ft. I'm not sure maybe someone will agree or disagree.
Joe
jmic is offline
Old 08-04-2006, 04:55 PM   #3
workman's Avatar
Trade: general contractor
Not a good idea to use rule of thumb...whos thumb? There are way to many variables to use a rule of thumb..what part of the country do you live in? How hot is it what are your "degree days", do you have single, double, triple windows? How many windows do you have? How much insulation do you have, how many doors? Is you house sealed well or do you have a lot of leaks in the windows or doors and there are many more. Have a HVAC manual J. Have I said enough? What is your return aiar size, what is you air flow rate, etc, etc. The rule is...there is no rule. Good luck!
workman is offline
Old 08-04-2006, 05:16 PM   #4
jmic's Avatar
I'll take this as a disagreement. I do agree with you there are many variables. I did say approx. And I'll admit when the hvac guy told me that I suppose he was thinking our area.
Joe
jmic is offline
Old 08-04-2006, 07:05 PM   #5
Teetorbilt's Avatar
You need a LOCAL pro. Personally, I went a little larger in tonnage as the old unit for one side of the house was running all of the time. 3 hurricanes later, everything has changed and the larger unit runs a shorter time. I'm told that this is not efficient with today's units.
Albert Einstein
Teetorbilt is offline
Old 08-06-2006, 02:12 PM   #6
Electrical & Plumbing
Atricaudatus's Avatar
Trade: Electrical and Plumbing contracting
I've been told something similiar. Bigger is not always better. "Short cycling" causes more problems with condensation and mold. An oversize unit doesn't run long enough to keep the ducting dried out. But I'm no HVAC guy, so I might be all arsed up. Just what I've been told. also we live in a very humid area (eastern NC) so that no doubt plays a huge part in the calculations.
Good HVAC guys, those who really know and understand all the variables and take the time to do the math correctly are sometimes hard to find, and those who do are worth every penny you pay for them in the long run.
Heating cooling costs are one of the major costs of operating a household in these parts and an efficiently designed and functioning system is an good investment.
-Rhett
Licensed electrician and plumber
Atricaudatus is offline
Old 08-06-2006, 06:30 PM   #7
MikeT's Avatar
Heres the deal,,,,
I went from 2.0 to 2.5 beacuse of not enough cold air...An I still don't fell as though I am getting enough...
My local Pro stated based on all his math, and calc, and experience this is what I needed for 1200 sq.
With 10 windows and gabriel vents although the home is cooler to me I was looking for 68 or so..
Maybe i just dream
MikeT is offline
Old 08-07-2006, 04:48 PM   #8
Chris G's Avatar
Trade: Porch and Deck Builder
68 Degrees? That's pretty low! I wouldn't want to pay that bill!
Chris G is offline
Commercial HVAC Reading Material TheRyeCatcher HVAC 3 07-26-2007 08:50 PM
New Guys denick Excavation & Site Work 29 01-11-2007 06:04 AM
What do you guys think of the big home builders? ruskent General Discussion 23 01-30-2006 09:08 PM
Need some feed back guys . . . Dually vs Single rear wheel. MEI MRG MM Vehicles 6 01-22-2006 03:21 PM
