Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 11-22-2008, 05:39 PM   #1
Brock
Trade: Residential Remodeler
HVAC Fan "ON" or "Auto"
Do you recommend keeping the fan in the on position all year, or auto.
I have always been told it is better to leave it in the on position year round.
Brock is offline   Reply With Quote
Old 11-22-2008, 05:40 PM   #2
Handle It!
MALCO.New.York's Avatar
I am with you on this one!!!
Originally Posted by MALCO.New.York View Post
Absolutely correct! It keeps the air "flowing" and therefore amalgamates the ambient temperature.
It does away with Hot and Cold spots.
It takes more energy to start a blower motor than it does to run one. No idea how long equates to "start up". But frequent start and stop is VERY wasteful!
Ultimate Wisdom---------
http://www.youtube.com/watch?v=_k1Ug...ture=rec-HM-r2
MALCO.New.York is online now   Reply With Quote
Old 11-22-2008, 05:49 PM   #3
"Leave it on," has been my
personal crusade for 30 years.
neolitic is offline   Reply With Quote
Old 11-22-2008, 05:58 PM   #4
cleveman's Avatar
Trade: custom home building
I remember in the instructions for my electronic air cleaner, it was stated to leave the fan on all the time for a month, then check and see if you can afford to leave it on.
Comfortwise, it is obvious that it is better to leave it on.
I'm going to find my multimeter and funky extension cord and get a reading on what it takes to run the fan.
cleveman is offline   Reply With Quote
Old 11-22-2008, 06:02 PM   #5
But you also have to factor in
cycling of the burner/compressor,
fuel use to comfort level, and life of the
start windings to get the total picture.
Old 11-22-2008, 06:28 PM   #6
Trade: GC - Home repair
I must be the only one that consider it a waste of money to run 24 hours.
I did try it on a new unit I had for downstairs because it came with a 2 speed motor. So did not cost much to run and would filter the indoor air all the time.
But after a few years had to replace the blower motor at a cost of $550.00 for this Carrier model.
rayh78 is offline   Reply With Quote
Old 11-22-2008, 06:37 PM   #7
Funny my last one ran continuously
for 15 years.
When the unit had to be replaced
I saved the blower and motor and
I'm still using it as a dust collector
in the shop.
Old 11-22-2008, 06:46 PM   #8
Brock
for 15 years.
in the shop.
I would like a master electrician to chime in here.
Which costs me more to run annually.
1. My full size rfrigerator in the garage I use for beer and extra frozen food that doesn't fitin my indoor fridge.
-or-
2. Running my hvac fan all year.
Old 11-22-2008, 06:50 PM   #9
Handle It!
Well...........What is the Wattage of the Fridge/Freezer????
According to the following site, an "Upright" Freezer uses 3 times the amount of energy as a "Furnace Fan".
http://www.oksolar.com/technical/consumption.html
Old 11-22-2008, 06:52 PM   #10
-or-
Fidge by far and away.
Old 11-22-2008, 08:34 PM   #11
Trade: Plumbing & Gas Contractor
Excuse me if I seem ignorant but I haven't heard of this before.You're saying that if I'm not heating or cooling my home that my fan should always be running,and that it is not hard on the system but better than letting fresh air into the home,or do you let the fan run and keep doors and windows open as you normally would during mild weather?
threaderman is offline   Reply With Quote
Old 11-22-2008, 09:28 PM   #12
How quaint.
That way I could actually find out
if there are any non-obscene lyrics
that go with the thump-thump "music"
as the cars sit at the stop sign.
I could make a hobby of identifying
the subtle differences in the tones
of each individual un-muffled motorcycle
engine.
Perhaps I might even learn to identify
the oil fields whence came the crude
by the nuances in the aroma of the
diesel fumes.
Perhaps you are right, I should open those
windows to the gentle breeze more often.
Or not.
Last edited by neolitic; 11-22-2008 at 09:53 PM. Reason: Couldn't find sarcastic smilie, too subtle
Old 11-22-2008, 09:37 PM   #13
How quaint.
engine.
diesel fumes.
Or not.
What the hell are you talking about,I like fresh air,I've lived in some of the toughest cities out there and still kept my windows open,and am only trying to figure out what's best for my HVAC.Maybe you should move to a more calming place,Holy crap.
Old 11-22-2008, 09:51 PM   #14
I didn't change, the city did.
I will take your advice and move
as soon as Mom dies.
As to the cost, my electric bill
is lower than anyone I know.
Every time POCO figures my budget
payments, I cut them by 30% and
still come up with a balance in the
settle up month.
And I don't think it would hurt
to move the air around the house
and through the filter even with
the windows open, maybe especially then.
Old 11-23-2008, 07:37 AM   #15
Trade: Lighting automation
What??
Do you run central air conditioning in the summer? If so, and you are in an area with high humidity, running a constant fan canl negatively affect your ability to dehumidify your home.
If your furnace/air handler is equipped with a variable speed motor, and depending on your thermostat, you can run an 'intermittent' fan which will allow the condensate to drain from your coil before running. Otherwise, it can be blown back into the air stream.
If chosen, mine will run 10 minutes on, 20 minutes off, if the stat has not called for cooling for an hour. Eliminates the stratification.
In wintertime, particularly if your unit is oversized and has a non-variable speed motor, running a fan w/o heat can cause a drafty, cold feeling.
It all depends on your system.
Delta
delta l is offline   Reply With Quote
Old 11-23-2008, 07:43 AM   #16
Handle It!
Originally Posted by delta l View Post
Do you run central air conditioning in the summer? If so, and you are in an area with high humidity, running a constant fan can negatively affect your ability to dehumidify your home.
Please explain..........With references.
Old 11-23-2008, 08:20 AM   #17
Delta
You are called.
Citations, proof, back it up.
Both common sense and long experience
is in direct opposition to your claims.
Old 11-23-2008, 11:10 AM   #18
Brock
Delta
I thought the same thing until I tried it. The opposite of what you are saying actually occurrs with the fan on. I think it is because the heat rises and will stay closer to the ceiling level while it is cycled off. With the fan running all the time it is cycling the air and not allowing cool zones throughout the home. We also keep our ceiling fans on low most of the time to aid in pushing down the warm air.
Old 11-23-2008, 11:13 AM   #19
Handle It!
Down in the Summer. Up in the Winter. Try it!
Old 11-23-2008, 12:30 PM   #20
Mmmmm, got your glasses on
backwards.
Warm air down in winter.
Cold air up in summer.
Think about what you want
to pool where, when.
hvac qualifier in Florida bgtonnessen HVAC 17 11-13-2009 12:53 PM
Hello from HVAC contractor witjr_49 Introductions 5 11-21-2008 06:13 PM
Need some HVAC opinions and help Mike B HVAC 5 09-07-2008 06:16 PM
HVAC Licensing question kdan General Discussion 2 08-25-2008 08:17 AM
Commercial HVAC Reading Material TheRyeCatcher HVAC 3 07-26-2007 07:50 PM
