HVAC Experts Need Some Help.
Bought a 2 story which has a single unit heat and air. In summer downstairs is comfortable while upstairs is hot. In the winter it's when it's comfortable downstairs it's hot upstairs. My thermostat is downstairs. Whats the solution to making the upstairs comfortable?
Re: HVAC Experts Need Some Help.
There is no solution other than the redesign the duct system. Improper duct design is the one and only cause for your issue. You can band-aid it a bit by dampering down the downstairs supplies to force more upstairs. This has it's limitations also, since you stand a chance of freezing the coil in the summer or shutting down on high limit in the winter. Also, keep the upstairs room doors open if you don't have a return in each room. You can try leaving the fan on "ON" instead of "Auto" to constantly stir the air in the whole house and even things out a bit. That might bug you though, but it often helps some.
Trade: H.v.a.c.
Depends on how much you are willing to spend. You could install another hvac system in the attic for the second floor or you could invest in a control setup with zone dampers. Your problem is common. There are several possible solutions. Obviously, not knowing the layout of your home, or your budget this is just a quick suggestion. But, I would bet a zone controler setup would be the best bang for the buck.
Trade: HVAC Contractor
get a zone system installed. Try to get one that has modulating dampers that are controlled in conjunction with a leaving air temperature sensor. If both of your zones are approximately the same size then it will work well for you. If your upstairs zone is a lot smaller, you might need an auxilliary unit upstairs.
NICKTECH
there are too many variables to determine the fix. but attic insulation and ventalation in the summer can decrease the temperature of the surface area of your ceiling a great deal relieving some of the load. the winter problem is most likely hot air rising to the upstairs as well as the warm being drawn there by the return (assuming the return is upthere). splitting the return, or completely rerouting it the the 1st flr could alleviate that.
| Leads.com - aka: Renovation Experts | FoilEffects | Online Leads Services | 21 | 01-05-2012 08:32 AM |
| Whats the benifits of being a hvac contractor vs non license? | Williamair | HVAC | 4 | 05-09-2009 07:59 PM |
| Preparing my education for HVAC career | pyroracing85 | HVAC | 4 | 04-30-2009 05:52 PM |
| Need some HVAC opinions and help | Mike B | HVAC | 5 | 09-07-2008 07:16 PM |
| HVAC Licensing question | kdan | General Discussion | 2 | 08-25-2008 09:17 AM |
