How Not To Do A Retrofit Dryer Vent
Old 02-13-2007, 11:01 AM   #1
alaska8515's Avatar
Trade: Builder
Although I like this product, I can not believe they posted this picture on their website.
dryerbox.com/photo_gallery/Digital/18.htm
Was going to post the actual picture, but they have a little blurb at the top that made me think the moderators might not want me to.
alaska8515 is offline
Old 02-13-2007, 11:08 AM   #2
K2's Avatar
Re: How Not To Do A Retrofit Dryer Vent
Just shows anyone can do it. Now we need the same guy to run some gas pipe and some 240v and some 120v and get another picture.
i like the idea though. I always seem to need another 4 inches of space for the dryer. I have fabed something similar in the past.
K2 is offline
Old 02-13-2007, 12:17 PM   #3
Teetorbilt's Avatar
Which comes first? Home collapse or fire?
Albert Einstein
Teetorbilt is offline
Old 02-13-2007, 12:47 PM   #4
Cabinetmaker
skymaster's Avatar
Trade: Cabinetmaker
Send a message via AIM to skymaster
Collapse, then fire, Bar-B_Q while waiting for fire dept
skymaster is offline
Old 02-13-2007, 05:18 PM   #5
mdshunk's Avatar
I use the DryerBox all the time, but not like that. Holy smokes!
mdshunk is offline
Old 02-13-2007, 08:37 PM   #6
Chief Toilet Mover
Mike Finley's Avatar
Trade: Bathroom Remodeling
Looks like it's up to code to me. As long as it's less then about 8 feet out from that last elbow. Isn't that one of the selling points of the dryer box, in situations where you are running out of allowable length like the one depicted, that it gives you an extra 5 feet by removing an elbow?
Mike Finley is offline
Old 02-13-2007, 10:29 PM   #7
mdshunk's Avatar
Except for those pesky boring and notching rules.
mdshunk is offline
Old 02-14-2007, 12:09 AM   #8
Chief Toilet Mover
Now you're just get'n picky!
I think it's just the way that a camera adds 10 lbs to you, and makes notches look out of code.
Old 02-14-2007, 12:19 AM   #9
Teetorbilt's Avatar
I'm REALLY hoping that it's not a supporting wall!!
What goes into that big box? A coil of duct tube? Add 5' per elbo and I really hope that you are close to an exterior wall.
Albert Einstein
Old 02-14-2007, 09:03 AM   #10
alaska8515's Avatar
Trade: Builder
My bet is exterior wall, little bit of insulation still there, hopefully not a two story home. But then again, just cover it up with sheetrock and problem solved.
It really does make a laundry room look good though.
Old 02-14-2007, 09:48 AM   #11
tcleve4911's Avatar
Trade: Remodeling contractor
If this IS on an ext wall, I would really be concerned about condensation & heat loss.
uh, er, side exhaust on the dryer????
At least head this thing off instaed of the hack!!!!!!
Shame on whoever did this........
Back in Maine
Dubbin' Around
Doin' good stuff ......
tcleve4911 is offline
Old 02-14-2007, 07:25 PM   #12
mickeyco's Avatar
Trade: Squirrel Handler
Holy crap, I can't believe they have that on their website. Assuming that's standard 4" dryer vent, the walls must be 2 x 6's, where else would you find 2 x 6's other than a exterior load bearing wall or a plumbing wall.
mickeyco is offline
Old 02-19-2007, 07:28 AM   #13
ozmy6's Avatar
Trade: Diesel Fitter
The phone jack says int. and the tile/whatever that is, maybe bath? But the insulation on the left says that dryer is in the garage or outside.
ozmy6 is offline
Old 02-19-2007, 07:41 AM   #14
ozmy6's Avatar
Tech tip-When using the phone think happy thoughts.
ozmy6 is offline
Old 02-23-2007, 10:55 PM   #15
MSSI's Avatar
Trade: Electrician
Hey MD have you ever notched or punched one to put the gas in there as well??
MSSI is offline
Old 02-23-2007, 11:45 PM   #16
mdshunk's Avatar
Nope. I'm just a sparky. Quite often I get saddled with dryer and bath fan venting. Don't do gas work, but that dryer box looks like a fine place to do the gas stub also. Certainly enough room, and the gas flex would coil back in there nicely.
mdshunk is offline
Old 02-24-2007, 07:14 PM   #17
MSSI's Avatar
Trade: Electrician
10-4 Thanks........I am doing a dryer setup this weekend comming up and am thinking about the dryer box, but it looks like I might just rock it and finish the recess. This one is my house otherwise I wouldnt be messin with the gas either.....
MSSI is offline
Old 02-24-2007, 09:45 PM   #18
It's all about the Avatar
woodmagman's Avatar
Trade: I have no face!
Don't worry about it! The drywaller can fix that. We have all seen worse. It is only someones home, a place where children reside. And besides laundry is typically done while they sleep so they will not be disturbed while that corner of the house colapses on their half dried clothes. And lets not talk about the duct on the phone lines, that is not life threating. Love the abilty that you can paint this box to match the decore behind the dryer!!!!!
This is a picture of the buisness end of the same dryer vent, notice the small lint build up.
woodmagman is offline
basement window with dryer vent hole dougchips Windows, Siding and Doors 6 02-26-2009 02:33 PM
Double Brick, Or Roof? Dryer Vent John S HVAC 3 03-23-2007 06:58 PM
Dryer vent question hanover Plumbing 12 11-15-2006 09:01 PM
Indoor dryer vent bucket Chris G HVAC 3 08-02-2006 06:28 PM
Dryer Vent?? Stephen HVAC 4 12-03-2005 01:04 PM
