Trade: HVAC
How To Make A Copper Coil????
I need to make a copper coil out of 3/4 OD soft copper tubing. It is turning out to be much more difficult than I imagined. I need to make two coils each containing 50ft of copper tubing. This is for a hot water application. I have tried manually bending the tubing around a 10in diameter PVC pipe, but the tubing flattens too much. I also attempted filling the tubing with sand with mixed results. I looked for coil tubing benders, but cant find one for 3/4in OD. Does anyone out there have a better idea or know of a tubing bender that would work for this? Any help would be appreciated. Thanks!
Alvin Baker |
#2 | |
Trade: Cabinets millwork spec builder
Re: How To Make A Copper Coil????Quote:
Have you tried an EMT bender?
#4 | |
Trade: HVAC
Have you tried slipping one of the plumber's bending springs over the tubing before you wind it over your PVC pipe form? Then, just slip the spring down the length of the pipe to support the tubing as you make the bends? I used to be an electrician in a factory, and this is how I saw the mechanics make chiller coils for small chemical vats.
#6 | |
Trade: HVAC
#7 | |
#8 | |
Trade: HVAC
Congrats!
| Trying to Expand Finding very hard to make it work | plazaman | Business | 27 | 08-13-2007 01:19 AM |
| Make sure you create an account AND LISTING in the directory | Nathan | General Discussion | 14 | 07-25-2007 10:38 AM |
| copper coupling popped loose | knyt | Plumbing | 6 | 06-13-2007 04:32 AM |
| looking to make move out of michigan | sterling stone | Help Wanted or Looking For Work | 2 | 02-24-2007 08:40 AM |
| copper epoxy | ELM | Plumbing | 6 | 12-11-2005 09:45 AM |
