Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-22-2009, 01:36 PM   #1
Custom Stuff
Mike(VA)'s Avatar
Trade: General Contractor - Custom Renovations
How do you keep cold air out of a range hood?
Never thought much about this before. Always just installed to specs and went on my way. This time, however, I remodeled my own kitchen and the vent-a-hood system lets so much cold air infiltrate down the ductwork that its quite cold around the stove area. You can feel the cold air just pour in. Are there dampers that can be installed in the system? Any solutions for a non-hvac remodeler? Thanks.
__________________________________________________ ___________
You are not making progress unless someone is trying to get in your way. I will never give up!
Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor
Mike(VA) is offline   Reply With Quote
Old 01-22-2009, 04:10 PM   #2
JonM's Avatar
They sell exhaust outlets with gravity fed doors on them...when the exhaust is activated the door is pushed open....
JonM is offline   Reply With Quote
Old 01-22-2009, 04:37 PM   #3
Custom Stuff
Mike(VA)'s Avatar
Ok, right now I have a dual fan unit pushing I think about 650 cfm. Each fan has its own damper. Doesn't do much good. The vent is a roof mount on a 3:12 roof. Not sure if a damper would work there.
Old 01-25-2009, 01:24 PM   #4
JonM's Avatar
This is what you need...it has a lightweight flapper inside
Old 01-25-2009, 01:55 PM   #5
Trade: roofing
You can usually find them at home depot or menards, braun makes them & has a damper that opens & closes.
Just a Roofer is offline   Reply With Quote
Old 01-25-2009, 02:22 PM   #6
dubz's Avatar
Trade: General Contracting
I had the same problem. Mine is a 10" round duct and it took a while, but I found an in-line spring operated damper to augment the one on the exit shroud.
dubz is offline   Reply With Quote
Old 01-25-2009, 05:08 PM   #7
Custom Stuff
Mike(VA)'s Avatar
Thanks guys. I'll make a trip to the HVAC shop and see what they have. I didn't think that a rooftop damper would be pushed open by the air, but maybe they have something.
Old 01-25-2009, 05:16 PM   #8
Trade: roofing
Yep, same thing goes for bathroom exhausts.
very cold outside air from cold air return ?? slawek HVAC 3 12-24-2008 09:30 AM
heating temperture range banctecbobn HVAC 3 10-24-2008 03:55 PM
range hood 60" above cooktop? Cache HVAC 15 06-07-2008 04:41 PM
FDA to declare cold medicines too risky for babies, toddlers eagleandbaby Off Topic (Non Trade) 0 01-17-2008 09:36 AM
Venting large kitchen range hood ChuckEA HVAC 5 01-12-2006 11:53 PM
