Hot Water System With Radiators
I have removed hundreds of these systems and replaced with hot water baseboard over the years. I have a customer that wants a new systems installed using radiators. Another contractor told me there is a pipe that can be used instead of iron or copper. Anyone know what it is? I assume it is plastic. I guess it could be used for baseboard as well.
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Re: Hot Water System With Radiators
Doesn't your heating contractor know what you are talking about?
He should. |
Have not talked to anyone yet, just heard about this this evening.
What kind of radiators?
He may be talking about PEX. |
These radiators are ancient looking things like the ones my father and I ripped out and replaced with baseboard years ago. I have a HVAC contractor who is willing to do the job but will not garrentee his work using those old radiators. The home owner is buying the radiators at a place called second time around, I called them, they are sold as is. I inquired about pressure testing them prior to purchase and they refuse. The contractor says it can be ran with CPVC pipe, I don't have much faith in this guy but he is the only one that would come look at the job using radiators which are so old. Have any of you guys used CPVC for hot water systems?
#6 | |
Re: Hot Water System With RadiatorsQuote:
DO NOT let your guy use CPVC for this. Man, just hearing this makes my blood boil. For a supposed professional to make a claim like that is disgusting. The guy is a hack, and idiot, and a fool. GRRRRRRR! OK, with that out of the way, there are many fine pros who will guarantee everything except the radiator itself. Go ask about this issue on www.heatinghelp.com. They might be able to put you in touch with a real pro who can do this for you. But don't let that CPVC hack onto your property again. No matter what, if he is that stupid, you don't want him on your property. |
You or your guy needs to get ahold of the EDR book to calculate what radiators need used where. I'm not even sure how your customer can even buy them without knowing about the heating requirements of each room and the EDR numbers for the radiators he/she's purchasing.
http://store.bnpmedia.com/store/aec_...see/index.html |
#8 | |
Trade: H.v.a.c.
Your choices are black iron, copper, and orange PEX. CPVC is nowhere on the radar.
#10 | |
Handle It!
#11 | |
CPVC cannot handle the kind of temps a hydronic heat system requires for a sustained period of time. I have seen it used like this. It caused over $23,000 worth of damage to the home when it failed. Failure came in less than 6 months of heating. |
Re: Hot Water System With Radiators |
Thom
I thought the old cast iron radiators were strictly steam heat. Are you guys saying that those same radiators can be used for hot-water heat also? It'd be interesting to see how that works, especially in a single pipe system.
Handle It!
I assume he means ThermaPex for Radiant Heat Systems!
Or Pex-Al-Pex??????? What ever that is!!! (multilayer pex) ![]() http://www.blueridgecompany.com/radi...ulitlayer-pipe
I have installed miles of barrier PEX and the only stuff that was orange (as opposed to red or clear/white) was Kitec. That's why I didn't understand what you meant.
Geographic differences then, I suppose. The only P-A-P PEX I've seen from any manufacturer has been orange in color. No big deal. I know the EVOH PEX can be any color under the sun. I suspect that's what you've been using?
#18 |
Handle It!
Just for the record..........There is, on the same site, an oxygen barrier, multi layer pex that IS black in color.
#19 |
| using attic to heat your water? | rhinoguy | Plumbing | 8 | 02-25-2007 08:04 PM |
| Water Tiles with well water? | depriate4repair | Plumbing | 10 | 02-15-2007 08:11 AM |
| Is it safe to drink water from Hot water Heater? | robertc65 | Plumbing | 14 | 02-04-2007 12:11 PM |
| Water cooled units tripping on high pressure | rookietech2006 | HVAC | 3 | 08-06-2006 08:56 PM |
| Closed loop hot water system? | K2 | Plumbing | 18 | 07-24-2005 10:06 AM |
