Hot Water Boiler, Burners Shutting Off
Old 10-16-2006, 09:42 AM   #1
r2d2's Avatar
Trade: HVAC
Need help on a hot water boiler, it is spark ignition, the boiler pretty much is sending 24v to the gas valve which I guess the spark box is ok and also it is sparking and lighting up the burners, but what then happens is the burners turn on for a few seconds then shut off immediatley, the b&g 100 pump is working properly but not heating up the apartment, please help
r2d2 is offline
Old 10-16-2006, 08:21 PM   #2
snapperhead's Avatar
Trade: commercial hvac repair and installations
Re: Hot Water Boiler, Burners Shutting Off
your stat runs the b&g pump even without the burner running the flame is controlled by the hi limit in the tank.check all your connections in and around the gas valve that thing calls sparks pilot lights and proofs the burner either the sensor is loose into the gas valve or carboned wipe it with a piece of sandpaper make sure that pilot flme is right on the sensor..check those terminals on the valve also might be loose
snapperhead is offline
Old 10-17-2006, 04:29 AM   #3
Bjd's Avatar
What type of boiler are we talking here? Is it power vented or direct vent?
Bjd is offline
Old 10-17-2006, 08:44 AM   #4
hf05's Avatar
Trade: hvac tech
Clean pilot so its nice and strong then yes clean flame rod with some sandcloth.If flame signal to control module is'nt sensed within so many secs .you won't get main burner.
hf05 is offline
Old 11-23-2006, 12:08 PM   #5
Tomgeer
Tomgeer's Avatar
Trade: Feild supervisor / install / service tech
Clean the flame sensor
Tomgeer is offline
Need a little lesson Tom M Plumbing 10 05-06-2007 09:09 PM
#&*@! Water Hammer! Mike Finley Plumbing 19 02-22-2007 11:47 PM
Help Water in Basement LG2720 Construction 12 01-17-2007 02:40 AM
Hot Water Joewho Plumbing 13 11-17-2006 02:39 PM
Brick Footer and Water Proofing emtaboy Excavation & Site Work 24 07-24-2006 09:48 PM
