Honeywell CT87K Issues
Old 10-12-2009, 10:00 AM   #1
Doer of Many Things!!!
gideond's Avatar
Trade: Paint and Floor Covering Retailer
I'm not a heating and air guy by trade but this was pretty simple swap out. I took an old Lennox thermostat out for my grandmother and put this Honeywell CT87K model in that she got from Lowes.
I've mounted it, leveled it and made the two wire connections (red and white) and it operates the furnace fine. She has a Ruud High Efficiency Oil/Forced Air system. However I'm having to turn the thermostat up to about 76 to get it to kick on and warm up to the targeted 68 mark she's looking for. I've set the switches on the back for high efficiency air per the manual. I've tried setting them back to normal forced air settings with no luck as well. Am I missing something or do I have a faulty thermostat?
Any input is appreciated. I'm a floor and paint guy so this isn't really my department but I never had an issue like this with the old T87 model that still had a mercury switch.
Thanks.
http://www.morrispaint.com
gideond is offline
Old 10-12-2009, 10:25 AM   #2
Steve
BACKWOODS's Avatar
Trade: Remodeling and Custom Cabinets
Re: Honeywell CT87K Issues
Does the new Tstat read 68 as the current room temp? The unit will only turn on if it is really cooler then it thinks it is. I have changed a lot of old units out in which the old mechanical thermometer was way off.
BACKWOODS is offline
Old 10-12-2009, 10:41 AM   #3
gideond's Avatar
Yeah, they set it on 68 last night. In the middle of the night my aunt checked it and the current room temp was at 62 and it still had not cut on. They have to set it on 76 to get the room temp up to 68.
gideond is offline
Old 10-12-2009, 11:03 AM   #4
Handle It!
MALCO.New.York's Avatar
There is a thing called Technology. With Solid State components. Some have dials for those who are not akin to advancement!
Chekemout!
http://www.azpartsmaster.com/images/...hop/A37320.jpg
AND!!! It is made by Honeywell!
http://yourhome.honeywell.com/Consum...nd/Default.htm
Stop relying on the old "Tried and True Tested", gizmos! (Hey wait!! this makes no sense!!!)
Give it a shot!
Ultimate Wisdom---------
MALCO.New.York is offline
Old 10-12-2009, 11:18 AM   #5
gideond's Avatar
Yeah, yeah, I know. Convince grandma of that! Regardless, this Thermostat should work in this application. The fact that it doesn't is irritating me. I'll swap it our for another one and if it still doesn't work right, something is goofy here. Maybe it just isn't compatible with her heat system, regardless of what it says.
gideond is offline
Old 10-13-2009, 07:00 AM   #6
gideond's Avatar
Taking it back today to try another. If that doesn't work, back to the old mercury switch until I find another unit to try. Thanks for the input.
gideond is offline
Old 10-13-2009, 09:02 AM   #7
flashheatingand's Avatar
Trade: H.v.a.c.
You might want to jumper the r& w wires. This will energize the heat circuit manually. If the system fires up right away, yo know it's a t-stat issue. If not, then you will sayve yourself a trip.
The stat that Malco posted is a nice one for the older folks who don't like "technology"
flashheatingand is offline
Old 10-18-2009, 01:31 PM   #8
gideond's Avatar
Took the CT87K back to Lowes where they threw it in a bin with about a dozen other Honeywell thermostats marked "defective".
Went to Hajoca (local plumbing supply store) and got a T87, which is evidently the exact same thing minus the wall plate that can be mounted behind it. It was $10 cheaper and worked perfectly. Lowes must get the seconds.
gideond is offline
Honeywell Training - Panama City/Ft Walton Beach Area Tbarnes Low Voltage 0 08-01-2009 10:53 PM
Board Thickness issues hailey Decks & Fencing 8 07-02-2009 10:30 AM
Homeowner Issues, squeaky floor, etc. monticellohomes Construction 19 03-30-2009 10:48 AM
legal issues tmcreno General Discussion 7 10-13-2008 08:01 PM
Honeywell Wiring Assistance arghh HVAC 4 08-28-2008 12:14 AM
