ALL VINYL
Trade: VINYL SIDING CARPENTRY
Honeywell Air Cleaner
I was wondering if its normal and I think it is for the air hepa cleaner to make a clicking noise like a bug zapper continuous when you first start it up . the unit is around 10 years old and I just cleaned the metal filters and discovered it was and probably never turned on . I also found that the switch on the unit wasn't on. I also noticed it works in the on position on the the thermostat and not on automatic is this rite .
Old School Marine
Trade: Union Journeyman Electrician
Re: Honeywell Air Cleaner
There is no airflow when the t-stat switch is in auto unless the heat or a/c is calling, so you won't hear any "zapping", it is normal when you turn it on after disturbing the unit to hear the buzz.
"If we ever forget that we're One Nation Under God, then we will be a nation gone under." Ronald Reagan |
ALL VINYL
THANKS for the reply and it makes since if thier is nothing going past it thier should be no noise , I have had it on for 15 minutes and it is still zapping not humming something like a bug zapper could this be dst particales ?
Old School Marine
Yes.
| TRION HE Plus 1400/2000 Air Cleaner | SHORTGUN | HVAC | 5 | 12-28-2007 08:26 PM |
| how do troubleshoot a Honeywell Zone valve? | bugdoc@linkny.com | HVAC | 9 | 12-01-2007 06:36 PM |
| Honeywell Vs. General Aire Air Cleaner | SHORTGUN | HVAC | 1 | 09-02-2007 05:46 PM |
| ez brush cleaner still available?? | lornmastro | Painting & Finish Work | 2 | 03-12-2007 11:39 PM |
| Looking for a good tile cleaner?? | Sellncars | Ceramic & Stone Tile | 6 | 09-03-2006 05:54 PM |
