Unregistered
Guest
Posts: n/a
High Side And Low Side Pressure Readings
Anyone know what the pressure readings(high side and low side) should be to determine if the system is low on charge. It's been many many years since i've worked on A/C units. I still have the guages but not the memory. I just can't remember.
The Doctor is In!
Trade: HVAC owner
Re: High Side And Low Side Pressure Readings
Without the proper superheat/subcooling temp. to go along with it, the pressures mean nothing alone.
#3 | |
Unregistered
Guest
Posts: n/a
Re: High Side And Low Side Pressure ReadingsQuote:
Unregistered
Guest
Posts: n/a
sh/sc and use a pt chart. Sounds like you aint got a clue. any refrigeration mechanic knows what a pt chart is and should keep one with him. probably aint even e.p.a. certified. sounds like you need to call a pro. Big fines if e.p.a finds out your playing with refrigerant and not certified.
#5 | |
Unregistered
Guest
Posts: n/a
The Doctor is In!
Trade: HVAC owner
Most manufactures have a charging chart inside the unit (outdoor). Depending on age, it could be faded or missing. Many supply houses have a slide rule chart for figuring superheat/subcooling and all you do is plug in your numbers for indoor and outdoor temps, wet bulb temps etc and see where you should be.
