Help This Train Is Leaking.
Old 11-02-2009, 10:11 PM   #1
Dr Heat
Dr Heat's Avatar
Trade: hvac
I was on a call today, 10 year old Train 90% builder model. The draft fan was leaking water. The original complaint was noisy fan. Here is the thing that caught my attention, the customer had two furnaces both leaked watter out of the venter motor. Any experiance with this is this a common problem with trains.
Dr Heat is offline
Old 11-02-2009, 10:20 PM   #2
solar guy
naptown CR's Avatar
Trade: solar contracting
Re: Help This Train Is Leaking.
I have never seen a train leak out of the fan.
the toilets usually just dump on the tracks though.
naptown CR is offline
Old 11-03-2009, 06:56 AM   #3
beenthere's Avatar
Trade: HVAC
Could it be from an improper vent system.
beenthere is offline
Old 11-03-2009, 07:33 PM   #4
NICKTECH
NickTech's Avatar
Send a message via AIM to NickTech Send a message via MSN to NickTech
choo-choo!!
NickTech is offline
Old 11-03-2009, 07:50 PM   #5
I like Green things
WarnerConstInc.'s Avatar
Train??
Originally Posted by Leo G View Post
Thanks for that tidbit of information Darcy.
Warner Remodeling ll Auburn Indiana Remodeling ll Dekalb County Remodeling ll Custom Woodworking Auburn Indiana
Warner Remodeling Facebook
WarnerConstInc. is online now
Old 11-03-2009, 09:56 PM   #6
Dr Heat
Dr Heat's Avatar
Trade: hvac
Well it is a 2" vent one pipe (plenty of intake air) about 20' long horizontal. 6' vertical. the horizontal is pitched toward the furnace.
The drain at the bottom is open.
Thanks Been for the serious response.
Dr Heat is offline
Old 11-04-2009, 05:17 AM   #7
beenthere's Avatar
Trade: HVAC
A small detail sometimes overlooked. is that when a condensing furnace designed for 2 pipe installation. Is installed as a single pipe system, and has a short exhaust. It can actually be pulling in too much combustion air.
And cause the flue gasses to be too cool, and have excess condensation.
Need a combustion analyzer to tell if it is the problem most of the time.
A CA would tell you how much excess air the furnace has. And you could restrict the intake until you had the O2 down to an acceptable level.
Also, check temp rise across the heat exchanger. Could be too low.
Old 11-06-2009, 08:12 AM   #8
MechAcc's Avatar
Trade: HVAC Service Technician --RSES CM-- NATE Certifie
Check the transitional duct between the secondary HX collector box and the inducer. They crack and leak. You'll have to remove the inducer to get access to the duct.
Check out the Trane furnace bulletin located at
http://docs.google.com/gview?a=v&q=c...9WpWqs4w&pli=1
MechAcc is offline
The Following User Says Thank You to MechAcc For This Useful Post:
Dr Heat (10-21-2010)
Old 11-12-2009, 07:36 PM   #9
hf05's Avatar
Trade: hvac tech
Would agree..secondary is cracked.yank ventor and check it out.Seen 3 within last week..
hf05 is offline
Leaking basement. lndnpride General Discussion 25 10-29-2009 10:34 AM
Anyone have issues with Grace Triflex 30 leaking? Morning Wood General Discussion 9 07-28-2009 10:58 PM
duomatic olsen leaking water Slyfox HVAC 1 07-27-2009 07:51 PM
Basement Window Leaking DanTheMan9727 Construction 3 10-24-2008 02:29 PM
leaking shower dlcj Ceramic & Stone Tile 18 10-09-2008 11:20 AM
