Help On Lennox Zone Board
Old 03-16-2009, 07:50 PM   #1
westernhvac's Avatar
Trade: HVAC Contractor
Hello everybody.
I am looking at a Lennox HarmonyIII 4 zone board. I have determined that I can definitely run a Hybrid system off of this board and it currently has a two stage AC installed. I want to run a two stage heat pump, but in reading through the install instructions it seems to mention two stage ac's but only single speed heat pumps. Any of you Lennox guys know if I can run a two stage heatpump on this board with a gas furnace?
westernhvac is offline
Old 03-17-2009, 07:30 PM   #2
flashheatingand's Avatar
Trade: H.v.a.c.
Re: Help On Lennox Zone Board
I don't see a whole bunch of fellas replying so here goes it. Is there a way to make it work? yeah, but my guess is that they are designed to for single stage h/p. so energize the y & y2. It's easy to say when you don't have the real job at hand. Heck, you probably already have it figured out anyhow. What's the answer?
flashheatingand is offline
Old 03-18-2009, 09:27 AM   #3
Thanks Flash. I didn't really figure it out, but I did decide on a course of action. Too much risk on the two stage, went with a single stage. The system is using propane as their furnace fuel anyway and their existing ac is only a couple of years old.
I'm just glad alot of people didn't answer and call me an idiot
Plywood over particle board PA woodbutcher Flooring 5 03-11-2009 07:09 AM
3 zone system propertyone HVAC 5 02-19-2009 06:42 PM
Stucco over Permabase Board? slapash14 Masonry 5 02-12-2009 08:56 PM
The problem with Lennox flashheatingand HVAC 5 10-21-2008 12:21 AM
Lennox HP29 control board anyone blowing fuses? crmont HVAC 3 01-04-2007 05:37 PM
