Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-15-2007, 05:20 PM   #1
Trade: general contractor
help i think
hvac is not my trade so bear with me please. i just built a house and had to use a new hvac guy. he priced me a 80% bryant furnace with 55000 btu. this home is 1750 sq.ft with 2 - 15' cathedrall ceilings. is this a big enough furnace there are 3- 4x12 returns in the bed rooms (1 in each rm)and 1 16"x16" in the living rm. the living rm and the master bed have the vaulted ceilings. hopefully this is enough info. anyway i was wondering if this is enough of a furnace for the home. i have 2x6 walls with the blown in blanket and roughly an r-40 in the ceiling ( blown-in) any info would help thanks in advance
benchmark2323 is offline   Reply With Quote
Old 01-15-2007, 07:35 PM   #2
AirPro's Avatar
Trade: HVAC Contractor
Send a message via Yahoo to AirPro
He should have done a manual J heat load calculation to properly size the equipment. If he hasn't... find another hvac guy that does it right, this is no place for guessing or rule of thumb calculations.
Here in Florida, you won't get pass plans review to even pull the master permit without one.
AirPro is offline   Reply With Quote
Old 01-15-2007, 09:16 PM   #3
how do you figure the heat load calculation
Old 01-15-2007, 09:26 PM   #4
Thoroughbred Mopar Man
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi benchmark2323
If you are a ACCA member its pretty easy to get this information. To do the calculation it will ask you windows, construction ,climate , etc. AirPro is dead on accurate, if he did not do this he needs to be fired. You may be able to go online to a ACCA site and download the manual J. Many things have changed since I got mine. One of the other guys may be able to tell you where to get it also.
Good luck
Rusty
#CARRIERMAN is offline   Reply With Quote
Old 01-16-2007, 08:16 PM   #5
AirPro's Avatar
http://www.wrightsoft.com/order/look...y=US&pid=RSR(J)
That is what I use to get the #'s, I then do the duct design and layout using a ductulator. You can buy the manual D add on to do this for you, but I couldn't justify the added cost to replace something I have been doing by hand for years.
There are also people that do these for a living, so if you won't be doing it more than once, you can just pay a certified energy rater the $150- $200 to do it for you....Or find an HVAC contractor that is professional enough to to the job right and include it in his bid.
Good luck!.
