Help With Heat Pump Problem
Old 10-20-2009, 06:27 PM   #1
72chevy4x4's Avatar
I had a tech come out and extend the lines on a heat pump an additional ~12'. The system worked as expected for the first week or so and then began to make loud noise from the compressor. I felt the supply/return at the compressor and they were both very hot (so hot I couldn't keep my hand on the tubes).
waiting on the tech to come back and diagnose-does anyone have a probable cause? Is there a recommended length of tubing?
the condensor unit is an Amana RHA18a2b. I've found an online service manual at http://johnstonesupply9.com/TechDocs...VICE%20MAN.PDF and looked through trying to identify maximum length of line run, but didn't find the info.
Last edited by 72chevy4x4; 10-20-2009 at 07:38 PM. Reason: added info re: condensor
72chevy4x4 is offline
Old 10-20-2009, 09:14 PM   #2
westernhvac's Avatar
Trade: HVAC Contractor
Re: Help With Heat Pump Problem
Could be non condensibles. Does it make noise constantly or does it get worse every few seconds?
westernhvac is offline
Old 10-21-2009, 09:36 AM   #3
flashheatingand's Avatar
Trade: H.v.a.c.
Page 23 indicates the lineset should be 50 ft. max and I think 20 feet max verticle rise. Were you already <50ft? I wouldn't think the added length is the source of the problem. How old is the unit? Hard to say what is going on, putting gauges on will help.
flashheatingand is offline
Old 10-22-2009, 10:27 PM   #4
DuMass's Avatar
Trade: EC/ACR
So, what did it turn out to be… oil logging… clogged BD/LLD… loss of charge maybe?
DuMass is offline
Old 10-23-2009, 07:35 AM   #5
Hvacr Professional
Hvacpro's Avatar
Trade: Hvacr Pro
Post
1. its a heat pump both lines will be hot in heat mode usually, to the touch.
2. they sound loud if they go into defrost mode, or when they shut off sometimes and the pressure will equalize.
3. the compressor hot gas bypass can sound horrible to or if the reversing valve gets stuck, due to improper voltage or weak coil or something of that nature.
I have a feeling it was in defrost mode, and its ok. not to worry.
But do have it serviced with the indoor unit for the winter season and every spring for summer.
Hvacpro is offline
Heat Exhaustion, Do you know what to do? PressureWashE Health & Safety 6 10-19-2009 09:55 AM
Existing addition on slab drainage problem dberkey1 Construction 4 08-21-2009 06:41 AM
Question "Carrier Heat Pump" Fix-it HVAC 1 05-13-2009 07:15 PM
2 ton vs 3 ton heat pump charlesmd HVAC 5 05-01-2009 10:46 AM
Tricks to sizing a heat pump Danno6102 HVAC 1 06-28-2007 06:05 PM
