Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Closed Thread
Old 01-17-2009, 11:57 PM   #1
Trade: HVAC
Help - Flue Pipe condensation
Hi - I was just hired into heating and AC and moved my hot water heater about 4 feet a week ago. To do this, a new elbow or about 45 degree joint in the flue pipe metal tubing was made. I noticed when we're using hot water and the hot water heater is engaged, condensation begins leaking from a very small leak in this joint between flue pipe pieces. I will note that it has been very cold here in Chicago this week, and I'm not sure if that has anything to do with it. I checked my roof, and while there appears to be a good amount of ice around the cap, it still seems to be on.
My first question is, even if I didn't have the leak, this water would be running back into the water heater top - is this normal at times? I would think rust would be an issue.
Next, what is the recommendation on how to best seal the joints between vents. I thought just 3 screws would do. With CO passing upwards, I'm concerned some could escape into my unfinished basement.
Lastly, part of the flue vent rests on a wooden floor joist before running upward to the next floor. I would think this gets too hot for that to be acceptable.
Please let me know your thoughts, and thanks in advance.
cubfan_mark is offline
Old 01-18-2009, 12:26 AM   #2
I think you need someone
qualified to see this.
Think of your family.
neolitic is offline
Old 01-18-2009, 12:31 AM   #3
Trade: Plumbing & HVAC, I specialize in Hydronic Heating and more specifically in Radiant Floor Heating
Hey, that's funny! On plumbingzone.com you said this:
Hi - I am an apprentice plumber
22rifle is offline
Old 01-18-2009, 12:42 AM   #4
I sniffed HO.
Pushed the ! as
soon as I answered the twerp!
neolitic is offline
Closed Thread
Drain Pipe denick Excavation & Site Work 18 07-12-2009 03:41 PM
Double flue down draft ELM Masonry 17 10-28-2008 06:48 PM
Very clean galvanized pipe. silvertree Plumbing 14 09-14-2008 02:47 PM
screws in flue pipe MattCoops HVAC 11 07-09-2008 05:37 PM
flue pipe soot problem magnum General Discussion 4 12-15-2005 10:17 PM
