#21 |
Re: Help!!!...... Advice For Waste Oil Heater Install
I'm right down the road from the St. Lucie nukie plant. Colorless, odorless, no problem.
#22 |
That's awesome. We need more nuclear, in my opinion. I grew up within sight of 3 Mile Island, near Steelton, PA. That one reactor that had the problem back in (79?) is still offline, as it's been dismantled inside.
#23 |
Chernobyl was awsome, 3MI wasn't bad either. We're becoming more self exterminating, maybe not a bad thing for the planet.
#24 |
Thoroughbred Mopar Man
Trade: Railroad Conductor/ Ex Hvac Service manager
Hi guys
I'm going to have to side with mdshunk on the nuclear power. We have one in Burlington Ks called Wolf Creek. It started up I believe in 79 or 80 and has been running every since. Besides it makes night fishing on the lake much easier, you dont need fish locator just look for the green glowing movement in the water, haha. In reality we have been killing ourselfs for alot longer than we have had nuclear or even oil power. The nut cases of the world have killed more people in one day than 100 Chernoble's could kill in a year. Rusty Last edited by #CARRIERMAN; 01-08-2007 at 10:05 AM. |
#25 | |
Trade: home building
Re: Help!!!...... Advice For Waste Oil Heater InstallQuote:
My name is Dan, I just ordered a waste oil burner and I am going to run cooking oil in it. I have some questions about the storage tank, I was thinking of using one of my old oil tanks and running a 1/2 line off of it to fill a smaller tank that I want to pre heat and and put another inline filter in.there is a small heated tank on the unit also,do you think this a good idea? And is there anything else that you can give me advise about prepping the oil and the holding tanks. Thank, Dan |
#26 | |
The number one reason for not installing a used oil burner is that they are high maintenance simply due to the contaminated condition of the oil. |
#27 | |
I'm Your Huckleberry
Trade: hvac
One singular chlorine atom can destroy over 100,000 ozone molecules. Why do you think we recover in the first place and why do you think R-22 is being phased out? Ozone. Jeezuz guy, watch what you say even if you don't believe it but if you don't then you have a lot to learn and in the mean time should speak for no one. Good lord, I've seen it all now. |
#28 |
Trade: hvac
Here, study some.
http://www.epa.gov/ozone/ http://www.epa.gov/ozone/science/process.html Large increases in stratospheric chlorine and bromine, however, have upset that balance. In effect, they have added a siphon downstream, removing ozone faster than natural ozone creation reactions can keep up. Therefore, ozone levels fall. Last edited by Doc Holliday; 01-13-2012 at 09:21 PM. |
#29 | |
Look, while I am, to some extent, a representative of CAS I am also an individual. I can say that CAS is very strict about following trade standards, including the EPA. As a matter of fact...employees get fired on the spot for certain "egregious" violations of company policy. One of them? Venting of refrigerants intentionally. That being said...global warming is a farce. It is a lucrative market actually. Just ask Al Gore and his followers...that is, if you can get them to be honest. The earth's climate has always had ups and downs and more important many ACTUAL sciencetists debunk man made "global warming". In terms of your comments towards a cholrine atom destroying ozone molecules. Just wondering how that along with the automatic assumption that CAS does not practice refrigerant recovery ties into my comments regarding a used oil burner? My comments regarding political issues or environmental concerns do not necessarily reflect the beliefs of CAS. Anyway....back to the original intent of the Thread starter. Furnaces designed to burn/utilize used oils for fuel are very high maintenance which is not really a big deal if you are willing to upkeep the equipment and wish to burn your used oils v/s dispose of them. Its simply a matter of knowing what you're getting into. PS....Doc I will start a thread on HVACsite.com regarding this issue of Global Warming so that we don't overtake this thread with unrelated discussion. Last edited by user84377; 01-13-2012 at 09:38 PM. |
#30 |
Trade: hvac
You are one strange, strange character my friend, but if I say potayto and you say potahto then so be it but let me ask you this, if men are from Mars and women from Venus, what the heck planet are you from?
#31 |
Trade: hydronic design, installation and consultation
Waste oil burners, furnaces and boilers are a good idea and Green as grass. In fact the EPA approves and encourages there use, as it is safer to convert/burn a potentially hazardous waste onsite, rather than to truck it cross-country.
Some waste oil units are better than others (especially true of boilers) but all require experienced regular maintenance by the manufacturer or properly trained owner. As with burning wood, knowing what to burn is important. In the case of waste oil, the mix is critical. We design hydronic heating systems, including radiant floor and snow-melting, using waste oil boilers-among others-and find they pay for themselves in short order. In some of our bigger jobs, less than three years. No one should install any hot burning appliance such as oil, waste oil, coal or wood without the help of an experienced professional. It is not only the considerable fire hazard but the critical need for minimum combustion air to prevent CO. As most steel buildings and pole sheds are very tight, this is of particular concern. Last edited by BadgerBoilerMN; 01-14-2012 at 09:49 AM. |
#32 | |
#33 |
Can I get an Amen?
Trade: Custom Woodworks
Waste oil is my friend.
U gotta clean it before you do anything with it though.
Yeah, I pay 50 cents a gallon for fuel www.wasteveggieoilexplorations.shutterfly.com |
| advice on materials? replacing old TNG beadboard soffits | jordanski | Carpentry | 7 | 05-01-2007 12:29 PM |
| Alright businessmen ... I'm gonna give it one more try ... breakin even | dirt diggler | Business | 30 | 02-27-2007 12:34 PM |
| Advice | DaveK | Flooring | 10 | 10-08-2006 07:46 PM |
| Need advice on this crown install challenge! | Richie-C | Finish Carpentry | 26 | 03-30-2006 09:58 PM |
| Water Heater Venting | rakes9720 | HVAC | 4 | 01-25-2006 07:28 PM |
