Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Closed Thread
Old 10-29-2008, 07:45 PM   #1
Trade: hvac
Lightbulb heat pump ?
Hey guys i am installing a 95% prpane furnace w\ heat pump my calculator does not include heat pump load it calls for 2 1/2 ton ac but it has 11ft cathedral ceiling Should i go with a 3ton. i have been told that going a little bigger will be better for heating. whats your oppinion?
allaroundcomfor is offline
Old 10-29-2008, 07:51 PM   #2
Professiona Instigator
rbsremodeling's Avatar
Trade: Design Build Remodeling Contractor Washington, DC
3 ton is to small in my opinion. 5 ton probably is optimal the calcs are usually based on 8 ft ceilings usually, so for 11 foot ceilings plus being that its a heat pump and not gas a few more tons should work out for you.
What did you run the calcs with???
Being an idiot frees a man from having to live up to others peoples expectations.
rbsremodeling is offline
Old 10-29-2008, 08:15 PM   #3
joasis's Avatar
Thanks for posting on ContractorTalk.com. The Moderators of this forum would prefer if you post Do It Yourself related topics on our sister site www.DIYChatroom.com
ContractorTalk.com is designed for professional contractor's to discuss issues and topics related to the construction and remodeling industries. Many of our professional contractors are also members at DIYChatroom.com and are looking forward to assist you with your needs.
Please take a moment to post your question at www.DIYChatroom.com If your not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.DIYChatroom.com/register.php/
We apologize for any inconvenience that this may have caused. This thread has been closed.
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
Serving Oklahoma Statewide
405 314 5802
joasis is online now
Closed Thread
Run a Heat Pump on solar power SR Martin HVAC 172 02-19-2010 02:14 AM
Heat Pump vs Central A/C mugiber HVAC 8 11-03-2008 11:13 PM
Tricks to sizing a heat pump Danno6102 HVAC 1 06-28-2007 05:05 PM
heat pump help!?!!! maxkd HVAC 1 11-10-2006 08:57 PM
Heat Exchanger Inspection Methods MechAcc HVAC 3 04-14-2005 03:38 PM
