Heat Loss Calculations
Are any of you folks familar with heat loss calculations? I have a couple of different programs I am trying to use but none of them have very clear directions. When they ask for the wall area, it does not specify if it is the exterior wall area or the total wall area. Certainly exterior walls would have a greater loss then interior. Also ceiling and floors, they do not ask if it is a single or two story house. Heat loss for the first story ceiling would be negligible where as the second would be greater.
Can anyone help me out here? |
Re: Heat Loss Calculations
use www.heatload.com and enter through "school pass". Just pick a school.
Plumbing is a Profession
Trade: Plumbing & HVAC
Loss calculations are always based on exterior walls only. 2nd floor calculations are figured same as 1st floor.
www.slantfin.com free software |
#4 | |
Re: Heat Loss CalculationsQuote:
So you are saying the heat loss thru the first floor ceiling with heated space above is the same as the second floor with unheated attic space above. That don't make sense to me but it might be correct. |
#5 | |
Trade: H.v.a.c.
Good luck |
Thanks Guys
Paul |
Trade: Sales/Distribution/Installation of low or line voltage radiant heating and snow melting systems
Think of it this way; A heat loss calc is based solely on the areas that loose heat. Interior walls that have heat on the other side are not used in the calculation unless they border an unheated space. The same goes for the floors and ceilings. Like FLASH said, enter the correct 'R's and correct window and door sizes. The most important concept in HLC's is this : garbage in/garbage out.
| Radiant Barrier Fact Sheet | Ed the Roofer | Roofing | 0 | 02-09-2008 08:57 PM |
| Heat Exchanger Problem with Hayward Pool Heater | jtc1062 | Pool Construction & Enclosures | 6 | 10-24-2007 10:33 PM |
| Heat Exchanger Problem with Hayward Pool Heater | jtc1062 | HVAC | 2 | 10-22-2007 10:13 PM |
| heat pump help!?!!! | maxkd | HVAC | 1 | 11-10-2006 08:57 PM |
| Heat Exchanger Inspection Methods | MechAcc | HVAC | 3 | 04-14-2005 04:38 PM |
