ditto that..... a heat exchanger can be trshd in a matter of weeks...
I'm guessing
1. rock bottom ph
2. zero alkalinty
3. chlorine in the skimmer & not running pump 24/7.....
ray
btw.... I bet h20 is crystal clear... common mistake , algae won't bloom in an acid pit & copper is an algaecide. the elemental copper that used to be in the heat exchangee is now in the pool. when you get around to balancing the H20 , don't be surprised to find "blue dust" throughout the pool. the dust is your hrat exchanger.
......Less with the jaw & More with the paw.....
