Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 01-10-2008, 08:24 PM   #1
Trade: handyman
handyman
I ran across a problem with the Rheem heat pump unit. At times the fan in the outdoor unit is not running and the heat in the house would run and doesn't shut off as it should when set on auto. I then have to hit the high pressure control reset button located on the outdoor unit to get the fan running and the heat would then shut off to the set temperature. I have to hit this high pressure control button atleast once a day to get the system to work properly. The filter is changed regularly. Please help.
handyboy is offline   Reply With Quote
Old 01-10-2008, 08:40 PM   #2
Trade: GC/Remodeling
I would probably bulldoze the house, and start over...just to be safe.
Or....call an HVAC contractor.
Originally Posted by jeremy-lvhm View Post
...just stop it. go sit down and have a lollipop and think about what your saying.
TimelessQuality is offline   Reply With Quote
Old 01-10-2008, 08:55 PM   #3
NJ Plumber with ATTITUDE
Trade: Plumbing Contractor
You have a refrigerant license? Cause you have freon temp pressure issues. And you have no idea that the compressor is off when the head pressure control trips?
wrenchman is offline   Reply With Quote
Old 01-10-2008, 09:35 PM   #4
HVAC Old Timer
HeatPro's Avatar
Trade: HVAC
I think he is saying that the heat pump compressor wouldn't run when the pressure tripped the limit. It would be normal then for the system indoor blower to run all the time until he could get heat from the first stage to satisfy the thermostat.
It is normal procedure for the heat pump to work that way; but it isn't normal for the pressure to rise high enough to trip without some mistakes or a problem. So call for someone who knows how to charge and fix the unit. It isn't for someone without gauges or knowledge:
http://www.heatpro.us/service/argues.htm#Charging
HeatPro is offline   Reply With Quote
Handyman getting into grass cutting 2500hd Landscaping 53 10-24-2009 06:45 PM
Handyman vs Contractor LNG24 Business 169 03-26-2009 07:32 PM
Few questions for a Handyman or Contractor in VA ButlerDesigns Business 5 05-22-2008 11:12 AM
HomeTech Handyman Cost Estimator Unregistered General Discussion 13 01-23-2008 08:43 PM
Help with pricing handyman services (TEXAS) Txbassboy Business 26 02-16-2007 06:10 PM
