Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 02-06-2006, 07:52 AM   #1
Remodeler
Trade: Remodel
gravity feed
On a 3 zone (circuit) hydronic baseboard system I have heavy gravity feed on the upstairs circuit. Each circuit is fed by it's own circ pump. Is there any other way to stop the feed other than a zone valve paralleled with the circ pump?
Thanks ...
Vermonster is offline   Reply With Quote
Old 02-07-2006, 05:38 AM   #2
Bjd
Trade:
Flow checks will stop the bleed from the gravity.
Bjd is offline   Reply With Quote
Old 02-07-2006, 07:37 AM   #3
Remodeler
Trade: Remodel
Thanks .... but why won't the gravity feed just reverse direction with a check valve?
Old 02-08-2006, 05:21 AM   #4
Bjd
Trade:
The flow check is weighted, so as to prevent the reverse flow.
Taco, and Watts make this type check valve.
BJD
Old 02-08-2006, 07:37 AM   #5
Remodeler
Trade: Remodel
great .. thanks a lot
Old 02-09-2006, 03:20 AM   #6
Bjd
Trade:
Take a peek around your system and see if there is a check valve on the supplys, note the one for the floor in question and be sure that it is in the closed position, if not it may just have something stuck in it and is keep it from closeing.
BJD
Old 02-09-2006, 08:28 AM   #7
Remodeler
Trade: Remodel
thanks ... I see the flo check valve and it is closed (top screwed all the way in). At that point does it need to be replaced?
Old 02-10-2006, 04:23 AM   #8
Bjd
Trade:
Yes I would say so
bjd
Old 02-10-2006, 07:49 AM   #9
Remodeler
Trade: Remodel
thanks for your advise
Gravity drainage basement systems skidmark845 Construction 5 08-01-2007 09:22 PM
Grundfos pumps , feed back Please tzzzz216 Plumbing 4 12-26-2006 09:06 AM
Feed back Please ,water heater Thermostat tzzzz216 Plumbing 4 11-11-2006 02:42 PM
A little feed back... Orlando IR Technology 11 05-11-2006 04:07 PM
HVLP gravity feed setup and techniques cblevesque Painting & Finish Work 5 08-01-2005 10:31 PM
