Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > HVAC
Old 10-04-2009, 08:13 PM   #1
Trade: Electrician
Goodman vent fan cycles
I have a Goodman GD-075 series furnace, the powered vent fan cycles for a few seconds every 10 or so seconds. Is this a control board failure?
Lazarus88 is offline   Reply With Quote
Old 10-05-2009, 08:15 AM   #2
Trade: H.v.a.c.
Assuming this is only happening during a call for heat, I would remove the leads from the motor and check the voltage. Then make sure the wiring connections from the board to the motor are good. Many times, the problem is simply a matter of a loose connection. If unit still cycles, it is likely the board is bad. Good luck
flashheatingand is offline   Reply With Quote
Stoping rain leak issues on vent stack with 2 90's? Security101 Plumbing 17 03-10-2009 12:05 PM
Vent Free NewGC HVAC 7 02-18-2009 05:25 PM
Bad plumbing vent pipe flashing Webman12 Roofing 5 10-08-2008 07:22 AM
ridge vent industry question USER8493893 Roofing 24 09-28-2008 12:52 PM
seal gable vents after ridge vent installed? tacoma5050 Roofing 26 01-18-2008 10:50 PM
