Goodman Not Cooling
Old 06-22-2006, 09:44 PM   #1
MikeT's Avatar
Trade: Remodeling, Home Improvement, Decks, Etc.
Goodman Not Cooling
Hi again
I am not an HVAc guy at all but I have a 6 month old Goodman heat pump with 8 rooms about 1200 sq feet, 10 39x55 double hung anderson windows, dark gray shingles, one 20x20 return in the hall, 6 inch flexible insulated ducting. The air handler and stuff are in the attic crawspace. I have 2 large Gabe vents, no fan, and soffitt venting as well. the house is 20 years old and the 200 sq ft addition was done this year. Every room in the house 2 ducts, and the extra room has 5 foot french doors leading into it.
The problem is during hot humid days in the 90's my house stays about 79 deg even with the digital lux stat set at 72...
Help me what is the problem ????
MikeT is offline
Old 06-25-2006, 10:39 PM   #2
dacusvillegirl's Avatar
Trade: Home Constructioin
Re: Goodman Not Cooling
for a 6 run it takes 4 vents to equal 1 ton so 8 vents on a 6 run equals a 2 ton unit - are you saying you have 8 vents or 16 vents - did you add vents to the addition - the 2 ton unit can't support the addition
dacusvillegirl is offline
Old 06-28-2006, 05:39 PM   #3
banctecbobn's Avatar
Trade: home builder
You never listed the sizing of your unit.
I'm afraid of having the same issue you are having when I have my unit installed. I hear lots of people complain about not cooling enough and not heating enough even though their unit was properly sized. It seems units are not sized for those few really hot or cold days of the year, in my opinion the most important days of the year. I'm actually thinking and wanting to force the issue of oversizing even though all the HVAC guys say this is the biggest mistake people make. I can already hear all the screams.
Have a great day,
Bob
banctecbobn is offline
Old 06-28-2006, 09:29 PM   #4
mas2006's Avatar
Trade: Electrical engineering
Do you have the correct amount of insulation for your area? Are your windows insulated glass and do they seal properly when closed. If not bigger AC unit not correct fix.
To the rational mind nothing is inexplicable, only unexplained.
http://roxyartwork.bravehost.com
mas2006 is offline
Old 06-29-2006, 04:41 PM   #5
MikeT's Avatar
I have a 2 ton unit installed for 1200 Sq feet with anderson doublehung windows X 10 and dark gray shingles with 2 big gabe vents, carpeted floors, ceiling fans, 8 registers, one 20x20 return in the hall
and all duct work is ceiling mounted.
The equipment is mounted in the attic ....
MikeT is offline
Old 07-04-2006, 09:15 PM   #6
Speer007's Avatar
Trade: HVAC
I will need some information, what is the model number of your condenser? Also how do your lines fell going into your duct work, is one cold and one just warm?
Speer007 is offline
Old 07-05-2006, 03:25 AM   #7
fluxonacut's Avatar
Trade: HVAC Appliance Repair
If your are 20 degrees below outside temp.In a 20year old house your doing well, with high humidity,very well.You can oversize the unit!!! BUT!!! how many day are Very hot?Start the A/C (set tstat to73) early on for said to be hot day
fluxonacut is offline
Another Goodman GMP-075-3 problem rhinoguy HVAC 12 12-05-2010 06:52 AM
Goodman 80% furnace brand new won't start Hguy HVAC 21 03-29-2008 12:05 AM
Cooling tower question. CC1 HVAC 0 07-26-2006 04:37 PM
2 blinks on goodman furnance? Herman HVAC 2 04-09-2006 11:16 PM
Goodman furnaces? oldgoat HVAC 3 02-22-2006 10:07 PM
